need help fast
need help fast
ok on the throttle body there is a vaccum line under the linkage, where does this line run to or is it capped off? if somebody doesn't know where the throttle body is it's under your air filter box. so can someone just run outside to their car and feel underneath the air box(if you have an intake it's the part where the tubing of the intake is connected to) and see if there is a hose running out of it and see where it's running to thanks.
ok one more thing i have a hose running from my oil pan to my turbo, i don't know if the hose is supposed to be there or not but if it is where should it run on a stock car. thanks.
em...the vacuum hose that comes out the back of my TB circles around to the left side of the car (right side if you're looking at the engine from the front). It then goes right next to the valve cover, turns toward the left side of the car (looking from the front), and turns into a hard line. then it turns back into vacuum hose and goes to the firewall. Why do you need to know?
solarpunk70
Apr 12, 2016 11:43 AM
IronFist
Sep 25, 2015 07:13 PM
meicalnissyen
Sep 25, 2015 12:12 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
