Hotchkis Rear Camber Kit Review *Pics Too*
DIY King
Yeah, so... Um... That's it. No, ok. The Hotchkis camber kit for the RSX is simply the best rear camber kit for our 7th gen Civics. I've owned the Ingalls (1st generation), the SPC, and now the Hotchkis. I'm keeping this one.
That probably says enough about it.It's expensive though. I paid $240 shipped. That's a downside. A BIG downside.
It's perfect though. It has zerk fittings on the polyurethane bushings. That means that you can grease it up with a grease gun. Fun! It has little bends on the Y shape that attaches to the lower control arm to make it a little stronger. The metal is coated in a thick black paint. The main part is aluminum. The threads come pre-lubricated.
It works. Easy adjustment. I expect little corrosion over the years. I reccomend it for the suspension freaks.
whoa! 240!!!!! i hope someone is paying you to test this stuff....i couldn't spend 240 like that...let alone own several kits....but your still the man
DIY King
See, the funny thing is I sold my Ingalls for more than I bought it for (made $30). Then I sold my SPC for more than I bought it for (can't remember how much more). Anyway, $240 - $30 = $210. A little better. The MSRP on those is $255. Ouch. I hope this goes down over time.
DIY King
Originally Posted by matrix311
Why are the Hotchkis better than the SPC? Besides the structure and material of how it's made and with the zerks, what advantage is there on having these over the SPC camber kit?
Do these allow for more + camber adjustment than the Ingalls? In other words, can it extend longer than the Ingalls, yet still have enough length threaded on? With a 2.25" drop, I am still running neg. 1.5 degrees of camber in the rear and I am scared to lengthen the Ingalls even more because it seems it won't be threaded enough to be sturdy and safe.
Ricerus Maximus
I just bought the SPC kit for about half that price, now I don't track my car that much so is it going to be suitable for my uses? With the rubber bushings of course the handling won't be as precise but is there any way to replace them with polyurethane?
DIY King
The SPC kit uses custom bushings as far as I can tell (no standard), so it's going to be kinda hard to find polyurethane ones. If you can find replacements, then it'll be easy to replace them. Then again, find something larger and grind it down to size. You need access to a mill though, so that's another problem.
Nalmonte
Jul 22, 2015 09:08 AM
BootyDo
Jul 7, 2015 06:06 AM
