Hotchkis Rear Camber Kit Review *Pics Too*
Old Jun 22, 2004
Grey's Avatar
DIY King
Exclamation Hotchkis Rear Camber Kit Review *Pics Too*
Yeah, so... Um... That's it. No, ok. The Hotchkis camber kit for the RSX is simply the best rear camber kit for our 7th gen Civics. I've owned the Ingalls (1st generation), the SPC, and now the Hotchkis. I'm keeping this one. That probably says enough about it.
It's expensive though. I paid $240 shipped. That's a downside. A BIG downside.
It's perfect though. It has zerk fittings on the polyurethane bushings. That means that you can grease it up with a grease gun. Fun! It has little bends on the Y shape that attaches to the lower control arm to make it a little stronger. The metal is coated in a thick black paint. The main part is aluminum. The threads come pre-lubricated.
It works. Easy adjustment. I expect little corrosion over the years. I reccomend it for the suspension freaks.
Old Jun 22, 2004
VNlilMAN's Avatar
The Standard One
looks nice but dayam $240
Old Jun 22, 2004
Mr.Modify's Avatar
whoa! 240!!!!! i hope someone is paying you to test this stuff....i couldn't spend 240 like that...let alone own several kits....but your still the man
Old Jun 22, 2004
civic01vtec's Avatar
damn .......... 240......i'll just stick with spc
Old Jun 23, 2004
Grey's Avatar
DIY King
See, the funny thing is I sold my Ingalls for more than I bought it for (made $30). Then I sold my SPC for more than I bought it for (can't remember how much more). Anyway, $240 - $30 = $210. A little better. The MSRP on those is $255. Ouch. I hope this goes down over time.
Old Jun 23, 2004
dacivic's Avatar
dacivic is an unknown quantity at this point
Grey you are rich!
Old Jun 23, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Hot damn those look sweet. TOo bad I can't afford them. Good review too.
Old Jun 23, 2004
flotsamm's Avatar
Looks nice.. but the Y bracket do look a little thin to me. I'm sure the little bends make it stronger, but damn they coulda made it out of thicker material I'd think.
Old Jun 23, 2004
PunkingCivic's Avatar
I need TP for my bunghole
Phat in appearance and price
Old Jun 23, 2004
matrix311's Avatar
matrix311 is on a distinguished road
Why are the Hotchkis better than the SPC? Besides the structure and material of how it's made and with the zerks, what advantage is there on having these over the SPC camber kit?
Old Jun 23, 2004
Pharoh's Avatar
Bobaganoosh!
Maybe expensive but so are my damn tires. Worth it in my opinion. Thanks for the review grey
Old Jun 23, 2004
Grey's Avatar
DIY King
Functionally they're the same. I.E. they do the same thing. The Hotchkis is lighter because of the aluminum. It's more corrosion resistant because of the aluminum and because of the thicker coating. It uses polyurethane for the bushings which is stiffer (better for cornering) while SPC uses rubber. It needs those Zerk fittings so that you can grease the polyurethane bushings. They squeek if you don't.
Old Jun 23, 2004
sheizen's Avatar
sheizen is an unknown quantity at this point
hotchkis makes great products and well worth the money...good choice
Old Jun 23, 2004
civicvtec1ps's Avatar
Search and Learn
Time to make replica camber kit grey.
Old Jun 26, 2004
blackdc5's Avatar
blackdc5 is an unknown quantity at this point
Do these allow for more + camber adjustment than the Ingalls? In other words, can it extend longer than the Ingalls, yet still have enough length threaded on? With a 2.25" drop, I am still running neg. 1.5 degrees of camber in the rear and I am scared to lengthen the Ingalls even more because it seems it won't be threaded enough to be sturdy and safe.
Old Jun 26, 2004
Vinh's Avatar
i can't even pronounced the name of the company
Old Jun 27, 2004
SlammedBlueEM2's Avatar
All Eyes On Z
Hawtch-kiss
Looks nice, Grey. But is it me, or is it that I don't see the ABS bracket?
Old Jun 29, 2004
dj02's Avatar
on the kit on the price
ill wait till they go down on price and pick up a set. wait wtf am i talking about. i dont use camber kits
Old Jun 30, 2004
Grey's Avatar
DIY King
I have an LX, so no ABS.
Old Jul 1, 2004
clownprince's Avatar
Ricerus Maximus
I just bought the SPC kit for about half that price, now I don't track my car that much so is it going to be suitable for my uses? With the rubber bushings of course the handling won't be as precise but is there any way to replace them with polyurethane?
Old Jul 3, 2004
Grey's Avatar
DIY King
The SPC kit uses custom bushings as far as I can tell (no standard), so it's going to be kinda hard to find polyurethane ones. If you can find replacements, then it'll be easy to replace them. Then again, find something larger and grind it down to size. You need access to a mill though, so that's another problem.
GolNat
Jan 12, 2021 09:06 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
Nalmonte
Jul 22, 2015 09:08 AM
chrisjackson321
Jul 12, 2015 03:00 PM
BootyDo
Jul 7, 2015 06:06 AM
