Need turbo guy experience... Rate my setup
Old Jun 21, 2004
BaLisTek's Avatar
i like shiny cars
BaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant future
On a scale 1-10
Help me out guys
GT28RS Turbo( It's a GT28RS. It's got a 62 trim T3 compressor wheel (new wheel), with a 50 A/R housing.. It's got an NS111 GT series turbine with a .86 A/R T2 exhaust housing.. also available in a .64 A/R T2 housing. It's dual ballbearing)
Manifold
Downpipe
38lb MSD injectors
Injector clips
Spearco bar and plate intercooler
Intercooler piping
Intercooler couplers
Clamps
Oil lines and fittings
Oil drain flange
Air filter
Greddy Emanage and components
Greddy Profec B
Monza Blow Off Valve
400cc injectors
2 bar map sensor
Walbro 255lph pump
Fuel return lines
Bosch fuel pressure regulator
Misc fittings
ACT Clutch assymbly
Vacuum lines and hoses
Forged Pistons/Rods
New bearings, seals, gaskets
Head studs
Solid motor mounts
Machine work
Blueprint and assembly
Block guard
Hot-tank and clean the block/head
Tuned and Dyno Tested
7100 installed
What do yall guys think
Old Jun 21, 2004
gotti's Avatar
wow @ the price!!!
Old Jun 21, 2004
abmerop18's Avatar
Jam out with your clam out.
price is a little high. i bet you can get all of that for under 4500. sounds like a good setup though
Old Jun 21, 2004
v8eaterokv6's Avatar
i have a new home do u
even with the pistons and sleeves
Old Jun 21, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Good deal... The price is not high considering a full motor rebuild, full turbo system with fuel management and spearco intercooler, new pistons and rods, clutch, labor, tune, blah blah...
Some minor concerns:
I didn't see sleeves... People have debated the block guard issue...
Solid motor mounts? Ever driven in a car with them? They are not for eveyone, especially with what you are building....
What about some port work and a turbo cam? Wouldn't raise the price much since everything is apart anyway.
Old Jun 21, 2004
allmotor's Avatar
nor cal 7thgens
everything in ur setup is nice but i would get a hks bov after seein that bov clip lol 7000 could also get u the k20a2 swap and it would make a little less hp but its relaible and n/a and alot of potential. i would do the swap but if u want turbo notin wrong wit that anyways nice setup and would u be in the 250-260 range tuned?
Old Jun 21, 2004
NoFriends's Avatar
I like ruining your threads.
thats def a chunk of change... Id rather drop that on a downpayment on an STI or something, but you will have one fast car no doubt!
Reginator
Jun 17, 2015 07:54 PM
cukaracha
Jun 8, 2015 05:41 PM
silverhx
Nov 14, 2001 07:04 PM
wsking77
Aug 29, 2001 05:34 PM
