Revo SS Install Info.
Old Jun 20, 2004
armieo's Avatar
< My future wife.
Edit: Install completed! A few helpful pictures enclosed!
I have taken off my 03 center console and everything....
How do I get the primary and secondary clutch lines out of the stock plastic housing? It seems like I have to turn it or something. The pimary line looks like it was MADE in the car or something. I do not see any leeway for popping/loosening.
Help. I'm DIYing it as we speak.
Old Jun 20, 2004
blouisgod's Avatar
Life Begins > 6800rpms
Yah, if I recall you have to twist the metal brackets 90 degrees out of the mount. Then turn them 90 degrees to install them.
Old Jun 20, 2004
armieo's Avatar
< My future wife.
Word I got it through trial and error. THanks man!
Old Jun 20, 2004
HelloPanda03's Avatar
HelloPanda03 is an unknown quantity at this point
yea, that 2nd cable is a B*TCH to get off! It took me a while to get it off.
Old Jun 20, 2004
armieo's Avatar
< My future wife.
Yeah the main cable you just kind of push foward along its length to the front of the car to get it loose....
ID:	31393   Click image for larger version
Old Jun 20, 2004
armieo's Avatar
< My future wife.
The secondary cable you have to turn it counterclockwise and it will make a small snapping sound. Then it slides off easy as pie.
You may have to use a flathead screwdriver... shove it vertically on the right hand side of that gray **** (the side with the little fin) at the 3'oclock position, and then pry the screwdriver so that it turns the fin counterclockwise.
ID:	31395   Click image for larger version
ID:	31396   Click image for larger version
Old Jun 20, 2004
armieo's Avatar
< My future wife.
It's easier to take out the metal rings from the rubber bushings before installing the bushings back into the newer shifter assembly. Insert rubber bushings and then push the metal rings in afterwards.
ID:	31399   Click image for larger version
ID:	31400   Click image for larger version
Old Jun 20, 2004
armieo's Avatar
< My future wife.
These are the things that kind of stumped me a little.. I'm just posting it to make it easier for anyone who is going to buy a revo SS in the future...
Old Jun 20, 2004
Nice! The only problem i had with my revo was that the threads were messed up. I couldnt screw down my aftermarket shift **** down all the way. It only went down half way. But it went down smoothly on my OEM shifter. I didnt notice this problem when i put my OEM **** on the Revo becuase the OEM **** is longer, and covers up the threads, so i didnt notice that the OEM **** didnt go down all the way.
anyone else have messed up threads w/ their revo?
Old Jun 20, 2004
armieo's Avatar
< My future wife.
Mine went all the way down i think.
Old Jun 24, 2004
518's Avatar
518
518 is on a distinguished road
I should have seen this thread before I installed my REVO SS yesterday. I couldnt get off the secondary cable to I used a hack-saw to remove it
The install instructions for 04 Civic is different and I thought 03-below can be easily removed. So I just used a hack-saw.
Other than that, it was a time-consuming job especially grinding down the grey/s washer with rubber liner. I installed Capyodas as well, and this shifter is solid!!!
Old Jun 24, 2004
518's Avatar
518
And I just found out that I'm supposed to take the rubber and the metal part before installing the Capyoda bushing But it still works while its on there!!!
edit: and on top of that, the washers are upside down compared to the install instructions
Old Jun 24, 2004
Drnknmnky13's Avatar
^^^ remind me not to let you work on my cars
Old Jun 24, 2004
518's Avatar
518
I constantly remind myself that! but hey, it still works and I get a compliment how solid my shifter is!
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
Theshwartz35
Jul 17, 2015 11:13 PM
