Can't believe this about K&N
Old Jun 14, 2004
StealthCivic's Avatar
StealthCivic is an unknown quantity at this point
Question Can't believe this about K&N
I have a K&N drop in filter, had one in my old crx too. I can't believe the new
statements about the simple drop in allowing dirt into the engine throttle body! I have believed the K&N was a step up from the stock air filter, which lets more air flow!! Is this a joke? I am still confused about this
Old Jun 14, 2004
zen_master's Avatar
i dunno too...
gear said that.....
however, i just checked my TB....after around 5000 miles.....my TB is definitely cleaner compared when i used that paper filter...
Old Jun 14, 2004
SMX's Avatar
SMX
SMX is on a distinguished road
A K&N, in proper working order, is one of the best flowing and better filtering filters available. A good paper filter will flow and filter as well for a short while, but plugs up quicker. Read Vizzard's articles on this.
If someone had problems with a K&N filter, it's probably 'cause they blew holes in it drying it with an air hose or somehow tore the filter.
Old Jun 14, 2004
djmota's Avatar
i have had my aem cai (K&N filter) on my car for about 25-30k miles. My throttle body is fine and so are the tops of my cylinders (very minor deposits) My car had about 50,000 mile on it when I did a head swap. I follow the instructions on the recharge kit and never use compressed air on the filter
Old Jun 14, 2004
zen_master's Avatar
that's what im thinking too..
i don't really think it's a good idea to wash and re-oil the filter...it's either you put too much oil....or you blew the holes out..
Old Jun 14, 2004
I let mine airdry for a few days to make sure it's dry. You can still see holes in it when holding it to the sun. I had dirt inside my intake tube and all over the TB and I use it exactly how you're supposed to.
Good luck to you guys who use it, but I will never put another K&N filter on my car.
Old Jun 14, 2004
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
Also: Read the directions that come with it. Never "blow out" your K&N filter with compressed air, that will only hurt the filter. A little dirt on the filter is supposed to help it anyway.
Old Jun 14, 2004
A dirty filter works alot better than clean by filtering more particles. Still not as good as paper or the apexi power intake. See my fix for the fipk in my other thread. Found a perfect replacement for the K&N cone filter.
Old Jun 14, 2004
I am keeping my K&n drop in filter in......I will check my TB just to see, but I bet it will be
clean ........
Old Jun 14, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
cant beat paper for filtering ability
http://www.bobistheoilguy.com/airfilter/airtest1.htm
Old Jun 15, 2004
I read the article you referenced. I guess it is a compromise, higher flowing air/letting more particles/dirt in vs. restricted air/more filtration.
But , is there really that much concern for 1% less filtration than Oem stock air filters??
---I just talked to one of the honda mechanics I know at Honda here, he has a K&N drop in filter, I told him about our debate, and the carbon buildup in the TB, he said the carbon buildup is not from the air filter, it is another reason , he asked what type fuel the guy was using...so , I am leaving my k&n in for good !(I may clean it soon though)
Old Jun 17, 2004
04em2's Avatar
04em2 is an unknown quantity at this point
The whole thing is ive seen filters that people have tried to blow out and nothing looks worse. paper or cotton doesnt matter its catch 22 but i'll stick to something i can clean every 3-6k
Old Jun 17, 2004
VVTSI's Avatar
VVTSI is an unknown quantity at this point
I have used them for years, but i cant say what the long term effects are because I rarely put more than 70k on a car before I dump it.
Old Jun 17, 2004
zen_master's Avatar
IMO, for the first 10K miles of the filter, K&N is the best filter u can get...
however...........................
once you clean it...or once it gets really dirty.........you can't rely on it anymore..
cleaning and re-oiling the filter will definitely degrade the filter itself..
ANYWAY....how many miles can you go with the OEM paper filter? or any other paper filter?
i checked the price for those filters....it's on the range of $12-$15.....that's like nearly half the price of the K&N itself (from AJUSA.com)!
