edit: 01-03 and 04 fog system not interchangeable
Old Jun 2, 2004
nitsuj1604's Avatar
nitsuj1604 is an unknown quantity at this point
does anyone know from experience or by comparing the two (not by guessing) that the 04 civic fog light switch will work with the 01-03 wiring. like is the plug on the back of the switches the same?
*edit* or if someone would be kind enough to take a pic of make a little drawing of the back of their 04 switch that would be awesome too
EDIT for those who care, they are not interchangeable. the problems are that the 01-03 switch is too small for the 04 opening to mount the switch and the switch lighting is reversed. the indicator light is always on (instead of illumination) and the illumination light turns on and off when you push the button. These are correctlable problems though. the 04 switch cannot be used in place of the 01-03 switch, one is a 5pin connector and one is a 6 pin connector. the wiring is also shorter but i may have just not routed the wiring correctly.
Old Jun 15, 2004
acidbaby's Avatar
The Beez Kneez
no........
mjdiaz89
Jun 21, 2016 09:26 PM
OH5LXSE
Jul 28, 2015 12:21 PM
Enigma346
Lighting
Jul 12, 2015 08:24 PM
elektrø
Jul 10, 2015 02:32 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
