R KONI yellows Height Adjustable?
hi all, i understand Koni yellows are damper adjustable but are they also height adjustable? I m fitting them into my 03 civic EX with eibach prokit so would be ground if height adjustable to minimise toe in/out problem.
please advice n thanks
The rear perch is the only thing that you can adjust for height, it has a stock setting or a bout an inch higher setting. If you plan on carrying a heavy load or towing(yeah right) then you might want to use the higher setting. Also with the Prokit, your not going to really have to do anything as it usually keeps the suspension alignment in spec.
Originally Posted by Zzyzx
They are not, they are just dampers. are you going from stock to the eibach springs, or do you allready have the eibachs in?
so i m planning to switch from stock to KONIs after hearing n reading much good things about them. any comment/advice?
Hi, no I dont have the Prokit, I have Eibach Sportlines with Konis. When you install Konis or just about any other strut/shock it shouldnt affect the toe angle. Dont worry about toe, be more concerned about the camber setting. When you have a really low drop then toe can become an issue.
However, even with the Prokit and Konis, you shouldnt have to buy anything else and your alignment will still be within stock specifications. The most you'll need with the Prokit is a rear camber kit only.
