Adding velocity to intake ?
Old May 25, 2004
redvtec04's Avatar
VTEC MASTER
redvtec04 should not be trustedredvtec04 should not be trusted
Wouldnt reducing the curved tube that mounts onto the throttle body add more power? Say a 3 inch intake and a 2-2.5 taper onto the throttle body.
I tried 2 different sizes, one was the same dia of the intake and the other a half inch smaller inner diameter but the outside dia was the same for easy attatchment and it makes more power.
Old May 25, 2004
dragoon's Avatar
nothing significant enough to notice.
Old May 25, 2004
civic01vtec's Avatar
don't know why you are wasting your time trying to make hp on these d17's.
Old May 25, 2004
Civicly02's Avatar
it is a hobby. I'm glad people have hobbys and brains for new innovation. Props on using your head to try and come up with brighter ideas
Old May 25, 2004
dragoon's Avatar
new innovations like tornado air intakes
Old May 25, 2004
skarteez's Avatar
skarteez is an unknown quantity at this point
tryin to do something like the V2 huh? with the two diameters (bigger then smaller leading to the throttle body) im guessing it would compensate for flow AND velocity. flow gives high end while velocity gives low end. when the air hits the smaller diamter, itll probablyaccelerate since it will have to conform to the smaller diameters.
but remember, adding too small an opening at the TB (source) could hinder airflow since at a certain point, there would be too much velocity and too little airflow.
you have to find a reasonable compromise between the two. stock airboxes promote more velocity than flow with therestricted areas inside the box, small filter and small opening. openelement filters (cai, sri) promote flow over velocity, since the open filter element throws low end torque out the window with very little vacuum pressire that is present with enclosed filters.
Old May 25, 2004
skarteez's Avatar
its good that you are actually usuing your brain with this stuff instead of "just buy an intake" comments, not that you say that. i compliment you even tho my english construction is bad.
heres a pic of my super-ghetto intake that has two diamters.
Old May 26, 2004
RedDragon333's Avatar
or the turbo BOV simulator
Old May 26, 2004
dragoon's Avatar
hey simma down now, haterade
Old May 26, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
You need a LOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOONG nozzle for it to work. A plumbing collector is too short of a reducer and it'll just cause recirculation zones, which inturn will actually reduce the inlet area to a size even smaller than the pipe, and slow it down since theres air basically moving "in reverse".
Old May 26, 2004
skarteez's Avatar
^^^ oh yeah good point. haah no wonder there seems to be something wrong with my "pipe." smoothness is key huh? especially for the airflow. dont want it interupted too much while in the airtract.
Old May 26, 2004
Well you want smooth airflow (for speed) up until the intake main, where the air should become turbulent for better combustion.
I like skarteez's intake, but it looks like it may not do the job as well as an aftermarket one.
Old May 26, 2004
skarteez's Avatar
^^^^ yeaaaaaaaaaaaaaaaaaah!!!! i know, it was more of a "hey look i made it and it sounds kinda cool" rather than "hey i made it and its plastic so its realgood."
thanks for the compliment tho
SammySC
121
Apr 7, 2017 07:43 PM
solarpunk70
Apr 12, 2016 11:43 AM
jtcavey
Sep 30, 2015 02:18 PM
juicetayne
Sep 30, 2015 11:02 AM
Cam Diaz
Sep 29, 2015 07:17 PM
