k swap or all motor
Old May 22, 2004
allmotor's Avatar
nor cal 7thgens
k swap or all motor
i have a little money saved up but i wanted to know is it worth goin all motor maybe nitrous on a d17 and i mean good i/h/e trottle body intake manifold ignition pulleys pnp full valvetrain clutch,flywheel and pressure plate fully built motor balanced and blueprinted with high compression pistons and on light enkei rims (9 pounds) falken tires 15inch and fiberimages hood and gutted interior with aem engine management and dynoetuned. i am lookin for reliable but fast where i can take it to the track. Will this setup run at least high 13's with or without nitrous or would u guys just do a k series swap which i wont be able to do for a while. Need info and help. I dont want to set records just hit 13's and i dont want turbo. I have seen fast single cams and bisi made me rethink the swap and see that u can make a sohc fast
Old May 22, 2004
kezay's Avatar
kezay is an unknown quantity at this point
Crower is currently developing a line of products for the D17's (cams, springs, retainers, valves, high compression pistons, rods...) they will also be posting dyno numbers once they are finished. So I say all motor .
Old May 22, 2004
dragoon's Avatar
if you wanna do all motor, swap is a great option
Old May 23, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Heh, so your answer to his question is both, because in reality they are the same.
Old May 23, 2004
ViNRoCk8's Avatar
#1 S2000 Fan
Not a bad idea K20a2's are putting out nice numbers all-motor. K24/K20 Frankenstein wouldn't be a bad idea either for all-motor
mistermenphis22
Jul 13, 2015 04:43 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
fatih717171
Jul 8, 2015 12:14 AM
supercivic01
26
Jan 26, 2002 10:11 AM
