Tien SS noise - hiccup sound
Old May 22, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
Is it normal for the shock to make this sound ?
I know it is not coming from the bolts or springs, this sound only happens when there is a small to med. hump in the road, which quite difficult to slow down for even if you are doing the speed limit. It can also be hard to avoid as sometimes they span the length of the lane.
So whenever the travel over these humps the shock makes that sound.
As mentioned before it only makes this sound when travelling over these humps.
Old May 22, 2004
robbclark1's Avatar
Retired suspension supermod.
all 4 of them?
Old May 22, 2004
MrWong's Avatar
Bushido
Just the two front ones, the speed i am usually going at is between 40 kph and 60 kph.
Old May 22, 2004
7thGenLX's Avatar
i have ss's and something is making some kind of noise similar to that but it might be my sway bars but then again i have a spec-v so idk
Old May 22, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
my front has been making some noise in the front right but i think i may have taken care of it.
heres what you do- spray WD40 inside your wheel well on the suspension itself. BAM, Fixed, worked twice now (rear had a squeek at one point also). It might take a day to go away but this seems to always work. WD40 is amazing.
Old May 22, 2004
MrWong's Avatar
Bushido
Yeah most noises have been elimated, I had to cut both rear dust covers cuz they were grinding on the threads.
In fact I found that most noises are coming from the rear, but I fixed all those noises.
2k2excoupe, you are correct WD-40 is amazing.
However, I do not think it will fix this sound. I am also begining to realize that this should be a normal sound. Because with my oem shocks they made a similar sound when going over humps.
Old May 23, 2004
ViNRoCk8's Avatar
#1 S2000 Fan
My Tein SS's will be going in next saturday I will let you know if I get any "noises".
Old May 24, 2004
EM2Civic's Avatar
EM2Civic is an unknown quantity at this point
my Tein SS have noise going over bumps too, I think it's just the sound of the shocks.
mokkush
Jul 14, 2015 04:05 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
1khilari
Jul 9, 2015 08:12 PM
fvckbg
Jul 7, 2015 07:08 PM
