WHEN YOU SHAVED YOUR CAR??
Old Nov 9, 2001
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
Hey guys when you shaved your emblems off your car, did you notice any paint peals? or anything like that? i am thinkin about doing that to mine but my dad says not cause it will make some of the paint that was around that come off after the removal of them. i am def. gettin a glow in the dark "H" emblem! those are sweet!
Old Nov 9, 2001
0100010's Avatar
0100010 is an unknown quantity at this point
No, no paint peels or anything. The emblems are just held on with double sided tape. Takes all of 5 minutes to pull them off, and clean off the sticky residue by rubbing your finger on it. Worse that will happen is you get a blister on your finger.
Old Nov 9, 2001
civiclized's Avatar
civiclized is an unknown quantity at this point
im not being a smartass, but "shaved" isnt quite the term that should be used...no paint work or other hard work is needed, ya know like bondo and stuff ...when i took off my embelms i used a blow dryer and no paint came off...its real easy, its also in the DIY section...also to get off the sticky tape like stuff u may wanna use some gasoline then rewash it and polish over it...trust me it looks alot better...clean look
Old Nov 9, 2001
JjAnGPeETuL's Avatar
JjAnGPeETuL is an unknown quantity at this point
Yeah, no paint defects. The annoying this is trying to get the glue off. After you do it, the car looks much cleaner.
Old Nov 9, 2001
BAK's Avatar
BAK
BAK is an unknown quantity at this point
Lighter fluid works good for getting the glue off.
Old Nov 9, 2001
xryder's Avatar
xryder is an unknown quantity at this point
no, no paint came off
Old Nov 9, 2001
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
5 months after i got my car !!! and i do have those H emblem that glow in dark, well actually i ran a wire to the emblem so when i press breaks it will light up
aZnVoYCe
Dec 7, 2001 12:41 AM
SQCivic
Nov 8, 2001 05:56 PM
wawacito
Nov 5, 2001 03:32 PM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
2k1TypeR
Sep 25, 2001 09:25 AM
