4 Disc Brake Conversion
Old May 14, 2004
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
I am looking to do the 4 disc brake conversion...
from the 1.7el how much am i looking for? and also what kind of parts do i need?
thanks
Old May 14, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Dunno if you wanna bother with the EL, as far as I see the 02+ SiR parts are about the same (probably EXACTLY), and someone has already done THAT on here.
That said, I've seen a few front-mashed EL's gettin towed about lately, you may be able to score one from a junker. That's what they get for tryin to outrun me round a curve, bwahahahahaaaaaa*burp*
Old May 14, 2004
TeLLy's Avatar
BTW:
Clicky for Si(R) parts list
Old May 14, 2004
TeLLy's Avatar
According to Hondaluver (whose signature makes me hard), the only parts you need to do the swap:
1. calipers
2. discs
3. spindles(knuckel)
4. e-brake cables from a rsx or si
5. dust covers. (picture below)
Copied from:
here
See how good I treat you?
Old May 14, 2004
Pharoh's Avatar
Bobaganoosh!
It's an easy mod for sure if you're not afraid of takin that kind of stuff apart. I helped Tekgnosis do his on his LX. Got the parts from a place in Montreal off a 2002 SiR.
Old May 14, 2004
jdm_bb's Avatar
. calipers
2. discs
5. dust covers.
so that's all the stuff i would need for this swap? how much am i suppose to look at ?
Old May 14, 2004
Pharoh's Avatar
Bobaganoosh!
Originally posted by jdm_bb
. calipers
2. discs
5. dust covers.
Tekgnosis paid $600 CAD
Old May 14, 2004
jdm_bb's Avatar
that's what my budget is around...
Old May 14, 2004
liljoe's Avatar
liljoe is an unknown quantity at this point
He got more than is needed though. He paid $600 for the full rear control arms, with everything still assembled on them. Makes the job a quick easy install (I know, because I bought them off him). I just dropped the old control arm, and lifted the new one in place. The hardest part was running the e-brake cables. The driver side one is a VERY snug fit.
A pretty cool mod though, the "feel" is great. It is so much easier to read the brakes now. I have an 01 LX (no ABS) and I don't think I'll ever lock up my tires again, and they are very bald.
Old May 14, 2004
jdm_bb's Avatar
LilJoe: I have 01 Lx ( no abs ) and i want to do this...
htan how much should i be looking for? and do u know where i can get them? cause i reaally want to get this done in this week or so
need to get ready for track
Old May 14, 2004
R1Style's Avatar
Won't you also need the brake fluid reservoir for the rear?
Old May 14, 2004
jdm_bb's Avatar
good question i would like to know too..
Old May 15, 2004
FurBall's Avatar
FurBall is an unknown quantity at this point
WHATEVER you do... DON'T do this
(Stolen from ClubSI.com forums)
Old May 15, 2004
Pharoh's Avatar
Bobaganoosh!
When we put his in we bent the guide under the car for the cable a tiny bit to get it in. Doesn't affect anything though so no worries.
Old May 15, 2004
SiRB16's Avatar
SiRB16 is an unknown quantity at this point
perhaps upgrading the master cylinder and rear brake lines is something to consider when doing the swap...
Old May 15, 2004
liljoe's Avatar
you don't really need to change anything as far as the resevoir, or master cylinder. The only thing you might want to do is get a brake proportioning valve. It adjusts the brake bias. But I don't really think Its necessary. I havn't AutoX with it yet, so maybe once I do that I'll change my mind, but for normal driving its pretty good.
I bought mine off someone else (he took them off when he sold his car), so I don't really know where he got them. Its some honda parts distributor in Montreal or something. All it is is the whole rear control arm from a SiR w/brakes and cables still attached. Then its just a straight bolt in, except the cables. I just snipped the ABS sensor wires. Also, because you have a 01LX (no rear sway bar), if you do it this way you get the rear mounting points for a swaybar on the new SiR parts. definitely a plus!!
Old May 15, 2004
iamfob's Avatar
iamfob is an unknown quantity at this point
does it make a big differences with 4 disc brakes vs discs/drums?
Old May 15, 2004
liljoe's Avatar
Its not a huge difference. It is nice though. The best thing is the feedback from the brakes is better. I can stop really fast, without locking up my tires now. Pretty good considering my almost bald tires. With the drums it was much harder to get the threshold braking right, without locking the tires. ABS is for babies
I haven't had a chance to be really abusive on them yet, so I don't know how much better they will be for track use...yet.
Old May 17, 2004
FurBall's Avatar
Though, it should be noted.. Even with 4 discs the Civic/EL brake feel is very mushy..... Not very sensitive to the driver, and not much feedback.... (I have stock 4 disc calipers, since I'm driving an EL)
Ah what the hell, go all out, and go for a full 4 piston caliper conversion
Old May 17, 2004
iamfob's Avatar
i think changing the stainless steel brake lines on the front would give u better result than doing the rear disc conversion. try the SS lines before doing the conversion and u will be surprise
Old May 17, 2004
tekgnosis's Avatar
Ask me about your mom.
SiRB16: agreed.
the one thing I didn't do was the actual pressure.
You'd also (in the long run) want to get an adjustable brake pressure regulator. that way you can fiddle with how much pressure goes to the rear brakes.
or, you can buy the non-adjustable piece from a 1.7EL. it's $140 or so (CAD).
stainless steel lines are also a good idea, but not neccessary for the short-term.
you should have bugged me on saturday while we were at the meet...I would have talked your ear off about the rear conversion I researched it to death a year ago!
Old May 17, 2004
jdm_bb's Avatar
Change the brake oil and brake line and it made a huge difference.
Old May 21, 2004
iamfob's Avatar
YES~
my friend changed the Honda brake fluid to Motul full synthetic brake fluid and stainless steel brake line and it was night and day.
I really wont bother doing the rear discs conversion cuz the rear dont get to use a lot to stop the car, most of the stopping power came from the front discs.
Old May 21, 2004
jdm_bb's Avatar
yea that's the brake fluid i am using motul rf600 something like that...
and the brake line i am going to get the bf good rich..
Old May 22, 2004
iamfob's Avatar
BF Goodrich make SS brake line?
Old May 23, 2004
dubz01si's Avatar
dubz01si is an unknown quantity at this point
LOL man that Vdub owner is a TOOL!
Old Jun 22, 2004
jdm_bb's Avatar
How much would the installation be?
Old Jun 24, 2004
liljoe's Avatar
I don't know how much installation would be. Probably WAY too much. If you have even a little skills, its a pretty easy job. Took me and my friend about 3 hours (with air tools). The hardest part was running the e-brake lines and bleeding the brake fluid. It's really an pretty easy install.
Old Jun 24, 2004
zen_master's Avatar
is it hard to change the brake line?
do i need to change different line for the front and rear?
how much is it for a good stainless steel brake line? any link?
thanx!!
Old Jun 24, 2004
zen_master's Avatar
help me plz..................
