Has anyone installed amplifiers under the seat?
Old May 13, 2004
winnerpl's Avatar
winnerpl is an unknown quantity at this point
Under the front seats that is in a 7gen civic. Good or bad? Any pics or just any info would be appreciated. Thank you in advance.
Old May 14, 2004
xmeeksx's Avatar
xmeeksx is an unknown quantity at this point
i have alpine installed under my passenger seat. well i didnt install it myself, but make sure if u do that the car is competely off..better yet..take out the battery because you're gonna have to take out the seat. taking out the seat may set off the srs light and its impossible tot ake it off without that ecu programmer dealers use. there may be other ways to turn it off though
Old May 14, 2004
doubledeuce2k2's Avatar
the amp can get hot under the seat, depends on the height of the amp. make sure there is adequate ventilation.
Old May 14, 2004
jjj784's Avatar
jjj784 is an unknown quantity at this point
i have two amps each under the seats. check for room and make sure there aren't wires or fuel lines running under the floorboard. don't forget self-tapping screws.
Old May 14, 2004
winnerpl's Avatar
for ventillation I can do something with pc fans. Has anyone done it in a civic? are there any fuel lines running under the floorboard?
Old May 14, 2004
civic2uner's Avatar
i put my amp under my pass. seat. easy
Old May 15, 2004
chicohonda02's Avatar
Since 2002 Baby!
mines under the pass. seat. Nice. might take pic later.
Old May 15, 2004
KaZeLL's Avatar
KaZeLL will become famous soon enough
i wouldnt do, i have done in the past to customers cars but i try to avoid if possible, people or passengers tend to kick or put there feet on them when sittting in the back, i dont like people stepping on my ****...theres no gas lines to worry about there, if you remove the seat ya the srs light will come on...there is a DIY for reseting this some where here on the forum..try the DIY section....for wireing up a fan well thats easy enough...just use the ground and the Acc wire leds from the amp...but make sure your not useing a cheap pc fan...the sell a tubular fan for this type of appliction....it puts out way more air then your regular fan
Old May 15, 2004
civic2uner's Avatar
here you go winnerpl..
Old May 15, 2004
civic2uner's Avatar
another
Old May 15, 2004
Hcivic01Vtec's Avatar
Hcivic01Vtec is an unknown quantity at this point
yeah this is not recomended, the amp gets too hot at times. If you could come up with some way to get a fan (better air flow) down there then maybe. But like kaZell said people kick it and could kick the wires off the terminals.
Old May 15, 2004
MegaHurtz's Avatar
bad idea
heat
dont listen to anybody whos install looks like civic2uners there
Old May 15, 2004
UltimateStock's Avatar
UltimateStock is on a distinguished road
Mhz is the ILL mc. word. nice name.
Old May 15, 2004
MegaHurtz's Avatar
w0rd
Old May 16, 2004
winnerpl's Avatar
Hey man don't hate on the looks. I'm doing this more for security and until I can do something myself in the trunk. Plus I just think it looks hot under the seat. Also more trunk space. And also I'll use a relay for the fans to cool the amp.
Old May 16, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
If you really want it there, I'd say to false floor the rear floorboard. Someone here has done it, and it looks alright, plus it will give you protection from people stepping on it and such. I'd think that you could use the floormat as a template for your cutout, but don't quote me on it.
Old May 16, 2004
angelswin's Avatar
angelswin is on a distinguished road
i just had to move my sub amp from under the driver seat due to overheating.I think most amps will be too big for are seats.i put mine in the trunk now and no problems.i agree,not under the front seats.
Old May 17, 2004
vicn77's Avatar
vicn77 is an unknown quantity at this point
i think it all depends on how you play your system...if you're going around and playing your system like you're in a DB contest then put it in the trunk...if not i believe putting it underneath the seats are fine...i had a 4ch and sub amp in my old 96 hatch and mine never overheated...even thumping all the way from b-more to virginia beach. but hey i had my windows down the whole time give my whole car circulation.
Old May 22, 2004
maxxam25's Avatar
maxxam25 is an unknown quantity at this point
mine is very simple custom box and it's not attached to anything or screwed on part of the body. I'll post some pic soon...
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
ballmich
Jul 9, 2015 11:59 AM
fvckbg
Jul 7, 2015 07:08 PM
