valve cover breather question
Old May 12, 2004
skarteez's Avatar
skarteez is an unknown quantity at this point
aight i was lookin at a raceversion RSX Type-S and it has a seperate cone-style filter for the valve cover breather hole. Also, the breather filter sits way off to the right side of the engine bay and is routed to the valve cover itself via an extended version of the stock breather hose.
questions!!!
if i just pop a valve cover breather filter right on the end of the opening without tube, wil there be ANY differences than if i place the breather filter away from the engine and connect it with an extended breather hose?
i have these questions cause my friend gave me piping for free that is bent kinda to SRI style. but i dont wanna drill too many holes in the tubing (only hole im drilling is for the air sensor). so yeah... thanks
Old May 12, 2004
civic01vtec's Avatar
It doesn't matter cuz nothing is not affected by the breather filter.
Old May 12, 2004
skarteez's Avatar
her4es the pic if people dont know what im talkin about
Old May 12, 2004
they have a catch can to catch the excess oil........ you don't need that, but it looks nice
Old May 12, 2004
abmerop18's Avatar
Jam out with your clam out.
whats that copper moton thing attached to the strut bar?
Old May 12, 2004
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
so if there is a chance that oil will spill out of that tube why the hell do ours go right in to the intake? thats just what I want in my intake. OIL. May be it will help the air flow smoother?
Old May 12, 2004
it is for emissions reasons. Take your car to get inspected and if they notice a breather filter and are **** about it, they won't pass you.
Old May 12, 2004
CrewChief's Avatar
why? I don't see the big deal?
Old May 12, 2004
well, it is part of the PCV system, which stands for ...... Positive Crank Ventilation. When our engines burn air/fuel, excess gases are produced. The idea of routing them back into through the manifold is to burn them off instead of releasing them into the air.
Personally, i think it is a bunch of .......... but i will continue using my breather filter
Old May 12, 2004
Spider883's Avatar
9K Redline Owns U
shock fluid resivor(sp)
Old May 13, 2004
skarteez's Avatar
would it hurt to get a seperate filter for the breather and mount the filter away from the engine and connect it via an extended hose? or would the shortest run between teh filter and valve breather hole be best? probably no gains huh?
Old May 13, 2004
i'd make it shorter though
Old May 13, 2004
acidbaby's Avatar
The Beez Kneez
so when you say "nothing" is "not" effected! so... somthing is effected
Old May 13, 2004
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
I've been researching PCV setups.. really the only reason you'd need to remove that breather hose is when you go turbo. the length of the breather hose affects nothing. having a filter right there on the valve cover, oil may begin to drip down and make a mess around the fuel rail. My setup will probably be similar to the pic shown, only i'd have another hose leading from that to the pre-turbo intake. If you look at this diagram, you'll have an idea what I mean. Look at the image for the first setup shown.
Old May 13, 2004
skarteez's Avatar
so no valve cover breather filter or chance of oil leak from the valvetrain? how come that wont happen with the stock setup?
Old May 14, 2004
Mex's Avatar
Mex
with a stock setup, there's not much pressure building up in the crankcase. air would typically flow into the breather hose into the crankcase, then out the PCV, being sucked into the intake manifold.
rarely oil vapor may sputter out.
Old May 14, 2004
skarteez's Avatar
im probably gonna be running wihtout a filter on the valve cover breather hose and cant connect it to the intake box for like one day. im chaning my oil next week so there wont be any problems right?
Old May 14, 2004
are you n/a or boosted?
if n/a then you will be fine.
LionSpratt
Jan 29, 2017 11:07 PM
Supramk3
May 11, 2015 07:55 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
