removing stock headlights
I've taken off the headlights a few times and it'd be really hard to take them off without removing the bumper, cuz there are the brackets connecting the headlights to the car.. its right under the headlight, its a 10mm, and the bumper is easy to remove.
Just take it off....don't be lazy. It's not that hard it'll make things much easier!
Search to man!! This has been covered numerous times !!
Actually, if you just let the bumper hang you can reach under the side right under where the fender hangs and you can unscrew the side screw that holds the under bracket, then you can get a long extension and unscrew the one that olds the under bracket closer to the grille. It's REALLY easy if you take off the upper grille when you do it. I have heard people with altezza grilles have it easier. In all honesty, you can take the headlights off without removing the bumper, but realize that if it's your first time.. you should just for the experience.
okay but why just stop at letting it hang from 4 little clips? just unclip them and take it off ....wow!!
ThE CoRRupToR
Originally Posted by nme3
yah i just let it hang, those clips underneath always breaks and it pisses me off
. I just let those 4 clips hold the bumper. Thread
stryder12
Jun 30, 2015 08:33 PM
