Electrical Help With An Underbody Kit
Old Nov 7, 2001
nickfn's Avatar
nickfn is an unknown quantity at this point
I ordered a red unerbody kit, and it should be coming in soon. But what I wanted to know was if anybody could give me some electrical help (even only what parts I should by) to be able to run the on/off switch to my underbody through the change cup, and install a switch there. I don't know jack about installing switches, gauges, or really anything electrical, but installation by a car shop would be anywhere from $125-$200. Unfortunetely, I don't have that kind of money right now. Any help would be appreciated!
Old Nov 7, 2001
SilverCivic2K1's Avatar
SilverCivic2K1 is an unknown quantity at this point
hmmmmm... I think it comes with some instalation instructions. but i dont know how to get it to go into your change cup. As for the switch, I think the kit comes with one.
Old Nov 7, 2001
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
Well, to start off, the kit should come with most of the stuff you need to install it. The tools and supplies I used were:
16 gauge wire
butt-connectors
Electrical tape
Drill
Drill bit
Screw driver attachment
2 friends
<a target=_blank href="http://www.streetglow.com/site/manuals/SG201.pdf">Here's </a>the link to the installation instructions for the Streetglow kit. It should explain how you should place the tubes under the car, and how to wire the tubes in series. If you need any more help, just send me a PM or e-mail. BTW, where's Mandeville and what kit did u get?
Good Luck!!
Old Nov 7, 2001
nickfn's Avatar
Mandeville is about 20 minutes north of New Orleans, Louisiana. Also, all it says is the &quot;Underbody Neon Lights Kit&quot;.
Old Nov 8, 2001
Boosted's Avatar
Boosted is an unknown quantity at this point
The install is a snap. and look at the DIY for remaoval of the center console to mount you switch...Also there is an 8 gauge white wire that come in tru the firewall, tap into it for you power. that wire is indirectly connected to your battery and the other end of the switch will goto the red wire on your transformer. Get some self taping screws to mount your tubes with. Also the transformer does not need a ground. The metal bracket that is made onto the transformer is also the ground. So make sure that you put it on something that is properly grounded...ie. driver side wheel well under the hood. that is where I put mine.
I hope that this will be of some assistance.
Old Nov 8, 2001
AEMcivic's Avatar
Hey Nick, if you drive to Lafayette, I'll help you istall your kit.
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Bruce2
Sep 27, 2015 08:45 PM
anubis62
Sep 27, 2015 12:56 AM
beanhead
Sep 24, 2015 12:04 PM
kevfarr
Sep 18, 2015 02:28 PM
