Weapon-R Secret Weapon Intake/Filter
has anyone seen this yet? its weapon r's new intake and air filter. it looks pretty cool. i wouldnt mind buying the air filter but i dont know if its for sale yet.
SECRET WEAPON INTAKE
The Secret Weapon Intake Systems is an result of countless hours of testing and tuning of air intake velocity, Airmass and Airspeed for each vehicle application. The Result, an intake system that performs better than any Cold Air Intake, but with a Short Ram. It is possible by Weapon*R's Patent Pending Speed Velocity theory, By creating a higher airspeed in the intake path you increase airmass and airspeed, which greatly increase horsepower.
This is possible by Creating two different paths of airflow, both flowing at different airspeeds, due to the tubing diameter in which the air is traveling. Now when the 2 different paths of air meet,they create a vacuum, which is where the airspeed starts to multiply, forcing more air into the engine at a higher rate, creating more horsepower.
The Secret Weapon Intake Systems are carefully CNC mendrel bent out of 6061 Aluminum, and then Hand Tig Welded in sections to ensure a constant balance in airflow, regulation in airspeed, positive seal and proper fittment. Each one of these intake systems are carefully tuned, by matching the engines displacement, air intake capacity and airspeed to the intake systems tube size,length and secondary pathway tubing diameters to maximize the full potential of the SECRET WEAPON INTAKE SYSTEM.
This Intake is Matched with our Newly designed SW1 Filter, which provides maximum airflow, with the protection of high quality dense Poly Urethane Foam. Many studies have shown Flow rates of up to 80% more Air and Better Dirt Filtration with Foam Filter than the conventional cotton filter. The SW1 main feature is an Computer CAD Designed and Flow benched Tested TURBO Velocity Stack, which greatly increases airflow ,airspeed and airmass into the engine, therefore increasing engine performance. Another one of the SW1 Filters great features are the capability to be dis-assembled to be cleaned and then re-assembled after cleanings or to change the color of the foam filtering element.
CARB PENDING:
http://www.weapon-r.com/
CARB PENDING:
Back From The Banned!
Originally posted by invasian
no offense but their names just sound gay..."dragon...secret weapon" wtf are they selling freakin war heads?
Weaaapon ARRRRRRRRRRRRRRRRRRRRRRRRRR
That website looks like it's years old. I don't even see the regular dragan intake for our cars, let alone the new one. Haven't been able to find ANY info at all about this intake online.
Filter on a stick just like the rest of them. Hope it adds an extra .0001hp over the rest, but what really matters is how well it holds up over time and do I need to worry about the thing falling apart while driving.
carid
Aug 8, 2015 05:05 PM
JoeB16
May 20, 2002 02:44 AM
