did i mess up bad and how do i fix it???
when i was installing my coilovers, i used the fork tool from kragen to pop out the tie rod end from the old shock
i don't think i tear anything but i pushed the inner rubber piece up. now the inner part is stuck upward. a lot of grease came out
how do i replace the rubber piece? they sell the rubber piece for like $2.50 and the whole tie rod end for like $50. i want to save the money since i still need $$ for alignment
do i need to remove the tie rod from the car. use a press machine to press out the old rubber piece and press in a new one?
how do i do this??
this is how it looks like now, as u can see, the inner part is no where touch the shock like how its suppose to
how do i do this??
Man..that sux...next time...GO SLOW. lol
Just go to your local Honda dealership and see if they can hook ya up with something. If that doesn't work, check a junk yard for a beat up/wrecked 7thgen. Tear off the tie-rod end and you're golden. But wrecked vic's are hard to come by where I live, so good luck. lol
I used the tie-rod fork too, worked like a charm, but I did tear the bushing...bad thing, but I'm not too worried. It's just some grease right...lol. j/k replacements are on their way..
This is seriously not that big of a deal! Autozone or Checker have these available. They don't fit quite the same as Honda's but they are more than sufficient. They are also red which might look cool with your suspension.
Anyway unless you are really strong you will probably just need a friend to step on coilover arm while you align the rod. I didn't need any special tools to get the boot off. Just a little elbow grease. Speaking of grease, don't forget to pick some more up while you're at the store.
Good luck!
Edited for spelling.
Good luck!
Originally posted by MrWong
If you do not replace/repair that piece will that affect handling ? or make noises ?
If anyone would like a DIY for this I could probably cook something up. It's actually pretty simple to replace.
Originally posted by usafstud
JIC
msrp:1980
my price : 1XXX, my friend told me not to tell or he could get in trouble from jic
JIC
msrp:1980
If the boot is still whole, can you see a way to just re-inject grease into it? Possibly flip up the bottom lip of the boot and squirt some back in?
Oh yeah, try this tool next time...
If those tierods were to be replaced would an alignment be neccessary.
I didn't use the tool Boilmaker has. That will make the job even easier. You could probably borrow one from Checker or Autozone.
Originally posted by Boilermaker1
Tie rod/pittman arm remover. $9.99 at autozone.
oh well, i'm going to try to fix it on thursday or friday
i might make a DIY
The best way to pop tie rods out is use a hammer to strike the side of the knuckle where the joint is and it will pop right out. Some people dont like to do it that way cause there is a risk of hitting the stud with the hammer and fooking it up. But ont the other hand using the fork ***** up the boot. But as for if you change the whoel tie rod, YES it should have the alignment checked. Can you get by with out changing the boot cause it has a tear in it? yes it mostlikely will last a long time before it wears out from exposure to the elements
Wow I just looked at my tie rod end and it looks exactly like the second picture. At first I thought something was wrong, but I guess it is supposed to look that way.
Am I correct ?
Am I correct ?
Do you have a digicam? Show us a pic.
Ahh i see.....so you just press the rubber hat ?
If all the grease seeped out will there be noises ?
I don't think you would here noises for a long while. You would probably have to get dirt or debri in there as well. It's just one of those things that if you don't fix, it will eventually catch up with you. ;-)
manh, I hate taking that Fu(king tie rod out. I've used the tie rod remover, the fork and the hammering technique but i still ended up damaging the boot a little. After driving it for a few weeks, I think the grease ran out and when i'm turning hard out of my drive way, I can hear a little "clink!" I hate that shiznit! Need to replace that boot but I'm not sure if you can just replace the boot or buy the whole tie rod that is attached to it.
i popped the rubber back out by squeezing the sides. i went to autozone and bought a grease gun with a needle injector. i squeezed the sides of the rubber so that i could get a small room for the needle to slide thru. packed it with grease. now its all good.
juror
May 26, 2015 06:35 PM
dragonsblood
Apr 27, 2015 12:28 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
