some help w/ wiring indiglow shift knob
Old Apr 26, 2004
StealthCivic's Avatar
StealthCivic is an unknown quantity at this point
Angry some help w/ wiring indiglow shift ****
Hey ya'll,
I need some help with installation of my indiglo blue shift ****, it is
cool, ,metal, hot as hell in the summer to touch after the sun...but looks
good lit up. I can easily install the shift ****, what I don't know how to
do is the wiring, it has 2 wires running from the shift **** to give it the
lighting ............?????
Old Apr 26, 2004
Nevermind, I searched and found some info, I will try what I found, but if you want to add anything about the wiring or what to connect them to , do it.
Thanks.
Old Apr 26, 2004
Project2k2's Avatar
probably a 12v....I would suggest this.
U probably have a red and black.
Black= ground
red = power
Run the black to yoru nearest ground.....I.E. frame of the car...even the firewall will work.
For the power, I would run it under the shift boot, then run it up into the cig lighter area. Behind there you will find the power...not sure what color but I thinks it's red. If you have a voltemeter try it out.
Splice into that wire with your power and walla, you got yourself an indiglo shift ****...
Another good point to ground it is under the glove box, theres a metal beem that runs under it, I have a few things grounded there.
Remeber, it won't illuminate if you don't have 0 ground.
Old Apr 27, 2004
DCivicEX's Avatar
DCivicEX is an unknown quantity at this point
That sounds pretty cool, have any pics?
Old Apr 27, 2004
slappyhoohah's Avatar
just dont screw thru the wire.... oops my bad
looked cool when i got it to work tho
good luck
Old Apr 27, 2004
TeLLy's Avatar
Yes, it's an Acura EL
I recommend tapping the wire into the parklight fuse, so it only comes on when you turn on your parklights (ie it's dim enough that you can see the **** light up).
Old Apr 27, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Black= ground
red = power
So my body kit is rice but a neon shift **** isnt??? COME ON MAN! WHERE IS THE LINE?
Old Apr 27, 2004
Project2k2's Avatar
I never said this wasn't rice....i just know about wiring...plus i wired my friend red neons that went under his seats.
Old Apr 27, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Yeah, yeah...
Old Apr 27, 2004
abmerop18's Avatar
Jam out with your clam out.
i think it is a given that all wallmart mods are rice
Old Apr 27, 2004
chicohonda02's Avatar
Since 2002 Baby!
I recently did mine a few months ago. I love it. I put a switch on mine though. I ran it to the cig. and everything else works well.
Old Jun 14, 2004
My (civic type r indiglo shift ****-for those that called it rice) is still layin around because I don't know how to wire it- thanks for the tips ya'll , but how do I even take out the center console and get behind my radio or dash? I don't know how to get to my dash or under the console. I will search too. Thanks
What_It_Do
May 10, 2015 05:31 PM
nbpEMCivic
Jan 22, 2002 12:56 PM
Flatlander
Jan 20, 2002 10:11 AM
AFlyer
Dec 22, 2001 01:18 PM
vexxed82
Dec 19, 2001 09:26 AM
