problems with hayame
Old Apr 25, 2004
DragonZ's Avatar
DragonZ is an unknown quantity at this point
Angry problems with hayame
i just installed my hayame coilovers and there is this weird clunk on my right side everytime i stern my steering well to the right but after a few minutes of steering back and forth form left to right it disappear but everytime i get in to my car that noise is there again. I had my friend if the hayame is hitting something while i turn the steering wheel he said nothing is hitting.
And one more thing im driving in the freeway when i reach the high speed it feels like my car is driffting left or right its kinda da scary especially driving at high speed and passing a vechile its seems like im going to hit them, thats why i always have both of my hands now on the steering wheel..
And can somebody tell me whats a good ride height and preload cuz i have 16" rims and i could never find the right setting so that ill stop bouncing around....
Old Apr 25, 2004
Yoyoio's Avatar
Yoyoio is an unknown quantity at this point
i think is either the preload is not enough, or the 3rd locknut thatz not tight enough.
try those first, and see what happen. Make sure the 3rd locknut is really tight.
if that doesn't do it, PM VNlilMAN. He should be able to help you out.
Ajust the preload first than height. This way you can have the preload you want.
Old Apr 25, 2004
gh0st's Avatar
TAQUITOS!!!!
my hayame's make a little popping noise when i turn the steering wheel in parking lots or in tight spots.
did you get an alignment?
Old May 1, 2004
canadian2k1si's Avatar
canadian2k1si is on a distinguished road
I also have the popping noise when manouvering through parking. Does anyone know what this is yet?
Old May 1, 2004
dacivic's Avatar
dacivic is an unknown quantity at this point
I too have the same sound. I still not have alignment done and wondering if thats the issue. 3rd nut is tight and I believe I have enough preload. Maybe it is a "settle in" issue.
Old May 1, 2004
Mine have been "settleing in" for a month, how long have your's?
Old May 2, 2004
dacivic's Avatar
only 1 week. Everything is tighten so I really dont know why it is making t hat sound. Sigh I hope it relates to alignment (gonna get one soon)
Old May 3, 2004
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
here's how i fixed mine...
1. Tighten your preload, and make sure you can't grab the springs and move them with your hands....when i had this problem, I could physically grip the springs and wedge them up and down, there was a lot of gap. After you adjust the preload, TIGHTEN, and i do mean TIGHTEN those 2 lock nuts, to secure the spring in place so when u drive, it doesn't unscrew.
2. tighten the 3rd lock nut also, VERY TIGHTLY
3. tighten all nuts and bolts that's used to mount the coilovers (mainly the 2 big ones above the brake rotor area.
4. GET A FRIGGIN ALIGNMENT, if you're drifting like i was, you SERIOUSLY need an alignment
One of those steps fixed the noise, i just dunno which one, i did the alignment first, and then did steps 1-3 b/c the alignment just fixed the slant in my steering wheel, and not the popping sound.
oh, last thing, if you have progress sway bars, or any sort of upgraded sway bars, TIGHTEN the hell outa the endlinks. Just don't strip them. I'm a relatively weak guy, so i just tightened as much as i could with my hands, which i don't think is much...lol...
i still get the clunking sound every now and then, but its pretty much gone. once youre hayame springs settle in, you'll be fine
Old May 3, 2004
DragonZ's Avatar
what do you guys recommend on the preload should i stiffen the front more than the back or vice vesas... and how much gap should my height between tire and wheel well
Old May 3, 2004
VNlilMAN's Avatar
The Standard One
the popping is most likely due to the 3rd locknut not being tight enough. you might think its tight enough but chances are its not...
as for the drifting.. yes its most likely because of alignment. main reason why i suggest you get an alignment when you touch your suspension especially when you change struts.
the preload... the front i barely had any. the rear i had a lot
the gap, you can make it as low as you want. with the hayames i had no gap all around. right now with d2s i'm slightly tuckin all around.
Old May 4, 2004
Sosojef's Avatar
Sosojef is an unknown quantity at this point
If you want to get rid of the clunking noise, try greasin up your spring coils, where they touch one another when the spring is compressed. I had that noise from my springs, and after applying some grease, all clunking sounds have gone away.
Old May 5, 2004
dacivic's Avatar
VNlilMAN how much pre-load did you have on your rear hayame? I have about .5 - .6" preload, lower all the way and still have 2.5 fingers gap left. Supposely I had the right rear springs 530.2.50.010. Did they ever find out the correct rear springs #?
Old May 5, 2004
ELaudio's Avatar
ELaudio is an unknown quantity at this point
I have the same problem with mine. In a way I'm glad to hear that others are having the same issue. I'm going to add some more preload and tighten the hell out of the lock-nuts. Hopefully that will solve the issue.
Old May 6, 2004
dragchic7681's Avatar
dragchic7681 is an unknown quantity at this point
Lightbulb
Hey guys,
I am very new into this so help me out. After I read all the issues I just went to buy one set for 650 shipped. Hope I made the right decision to go for hayame.
What does it mean when you guys said add some more preload.
I am going to ask my friend to help installing this but I need to know everything ahead of time so I won't freak out later.
Please post it up here If you have good instructions to install this product. Thanks all, Civic01
Old May 6, 2004
dacivic's Avatar
Read the whole link here http://www.7thgencivic.com/forums/sh...hreadid=134001
Old May 6, 2004
strider_rsx's Avatar
strider_rsx is an unknown quantity at this point
Man i guess im not the only one.... ill get back to you after i adjust everything.
Old May 7, 2004
SlammedBlueEM2's Avatar
All Eyes On Z
They just said that the springs were mis-matched and those are the right springs. If you're still having height issues, please let Mike from UrbanImport know. I'm sorta convinced that the issue is not solely mis-matched springs but we'll see eventually once I get my new ones.
Old May 7, 2004
dacivic's Avatar
I am curious as well. Tried to ask few members who had a lot of pre-load on the rear and still able to slam (but their mailbox are full)
Slam let us know if it is just the spring? It could be something else. If I only have a little pre-load(like .1 inch) I can have 1 finger gap.
Old May 7, 2004
VNlilMAN's Avatar
The Standard One
well it also depends on what tire size your using.. if your running 205-40-17 of course your going to have some gap..
my friend is running 215-45-16s and he has a 2-3 finger gap even with neuspeed race
Old May 7, 2004
dacivic's Avatar
Right now I have stock wheels on(185-70-14) and I have 2.5 fingers gap with about .5 inch of pre-load(this setting is a must w/o bouncing all over). I am wondering how much pre-load you had at the rear to have almost no gap. Hopefully it will just settle after a few week.
Old May 7, 2004
VNlilMAN's Avatar
The Standard One
I didnt measure but it was pretty much as tight as i could using my hands. this is by grabbing the spring along with the perch
Old May 11, 2004
dacivic's Avatar
ANyone fixed this yet? I tried everything but I couldn't figure out how to stop the noise.
Old May 11, 2004
All Eyes On Z
Bleh, I'm just gonna consider it defective since it's a new product.
Old May 11, 2004
VNlilMAN's Avatar
The Standard One
most noises are an installation issue
Old May 11, 2004
01EXtc's Avatar
01EXtc is an unknown quantity at this point
its the upper bearing your missing. i had the same prob on my konis, worked fine for me after i installed them. PM me if u need details
Old May 12, 2004
All Eyes On Z
If it's missing that part, then it's most definitely defective.
Old May 12, 2004
VNlilMAN's Avatar
The Standard One
koni's and hayames are two totally different things.. koni's require stock upper peices while hayames dont.
Old May 12, 2004
All Eyes On Z
I'm done with Hayame coilovers. I'm assuming the information UrbanImport received about the next shipment was false. It's just about to be the middle of this month. He has had no updates since the middle of April.
It is beyond the time to ask, what the **** is going on... ?
Old May 12, 2004
01EXtc's Avatar
I stand corrected. I looked at what they said was the issue and thats how i fixed mine. i wasnt aware of the mount issue. however, in most cases, the popping noise is caused by that. best of luck to you
Old May 12, 2004
dacivic's Avatar
Mex and I installed the hayame and I believed we did everything perfectly. The noise was made by twisting the springs while turning the steering wheels. I tigthened everything up so there was no loosen part.
Don't tell me the coilover are missing some parts. I spent half a year of saving to get them.
domesticsnyper
Jan 7, 2002 08:50 PM
supYO
Jan 4, 2002 12:46 PM
LexBoy
Jan 2, 2002 07:59 AM
Aznnp77
Nov 28, 2001 09:17 PM
