What is your camber set to?
Old Apr 14, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
What camber setting are you guys running and what suspension are you running it with?
Old Apr 14, 2004
Zzyzx's Avatar
Autocross Junky
what are you doing with the car?
If its just used on the street, then less then -1 deg, probably less then -.5
Drag race 0 on the nose
Road race, -1 to -2 on the front (depending on the course) -.5 to -1.5 rear. once again depending on the course.
autocross... as much as you can get on the Front, at least -1.5, rear -.5 to -1.5...
These are just ranges, testing and tuning will give you the best camber angles.
Old Apr 15, 2004
Logan3024's Avatar
i currently am at -.3, this is the best i could get with 225 18/40's. Suspension, Goldline and konis.
Old Apr 18, 2004
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
0 in front and -.5 in the rear for a little bit extra traction. However with 24000 miles on my tires, the inside is eaten up a little. No biggie, just flip them.
Old Apr 18, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
i dunno. the shop just set it at whatever perfect camber is when i installed my tein ss and my spc camber kits *front and rear*
Old Apr 18, 2004
MIT's Avatar
MIT
MIT is an unknown quantity at this point
i dont know either, just bring my car in then they set it at whatever for me...tein basic and spc camber kits
Old Apr 19, 2004
Intruder's Avatar
Intruder is an unknown quantity at this point
I am at -0.7 degrees on the fronts and -1.0 degrees on the rears (need this for fender clearance). I have the ingalls rear kit and no front kit on H&R Sports and Koni's
Old Apr 19, 2004
Zzyzx's Avatar
Autocross Junky
the Proper camber, caster and toe settings are all dependent on your application.....
and the manuufacturers recomended alignment isnt really conductive of a well handling car... Its designed to keep you safe by, Making the car understeer, and be stable going down the Highway in a straight line, as well as Getting the maximum tire life.....
For a more Performance based alignment you have to be more agressive with the alignments, and From what I've learned, the Proper alignment can mean the difference between an Understeering pig of a car and a Tossable, fun to drive automobile.
Of course finding out what alignment sutis you best means testing and tuning, as with all things. Heres a little reccomendation, Run more negitive camber on the nose then the rear (Some where between -.75 and -1.5 front would probably be good for the street), and possibly run 0 to a little toe out on the front, and 0 toe on the rear... Maybe a little Toe in or out depending on if the car is understeering or oversteering.
happy racing, and keep the shiny side up.
GolNat
Nov 27, 2018 03:32 PM
Dave Brabant
20
Oct 6, 2015 12:44 AM
Wheela
Wheels and Tires
Sep 7, 2015 02:14 AM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
