HELP! I cant rev past 4k
Old Apr 3, 2004
cdmx's Avatar
3.9k to be exact!
I dont know what happened!!!
has anyone experienced this?
I was going like 60-70 on an on ramp when all the sudden 3rd gear cut out...like im hitting the rev limiter!
I have I/H/E with highflow downpipe, no mil eliminator
anyone know what my problem could be?
I would hate it so much to have to put everything back to normal in order to take back to dealership
Old Apr 3, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
No clue, but sounds like the ECU is in limp-home mode. A codereader would tell for sure.
Old Apr 3, 2004
cdmx's Avatar
So weird, i get to my friends house and elave at 11:45 and its fine....nothing
has this happened to anyone?
Old Apr 3, 2004
Pharoh's Avatar
Bobaganoosh!
never. but as suggested....you might want to get a code reader hooked up to that biatch to see if there's a problem.
Old Apr 3, 2004
keepin_it_clean's Avatar
keepin_it_clean is an unknown quantity at this point
it went into limp mode....if it does this again, just cut the car off and restart it, it should run and idle fine again
Old Apr 4, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
several ppl had this problem. Is this a problem for autos only or stick and auto?
Old Apr 4, 2004
Island2K2's Avatar
Island2K2 is an unknown quantity at this point
yes, dont worry about checkin the ecu theres no codes to find and on our cars theres no such thing as a rev limiter because thats the ecu
the problem with your car is the timing belt tensioner is weak and your car has jumped time its probably retard by 3 or 4 teeth go get your timing belt tensioner changed and new timing belt and your done
this has only happend to me 2wice on 2 out of 3 motors hope you got 200 bux saved up for shop time
Old Apr 5, 2004
cdmx's Avatar
omg!
but everything seems fine now
think it was just limp mode? and anyone want to explain that one
Old Apr 5, 2004
cdmx's Avatar
Originally posted by cdmx
omg!
nm, i searched like a pro and not a n00b
"Fail Code" conditions or "Limp Mode" happens when the vehicle computer recognizes a problem in it's logic. When an expected signal value from a sensor is sent to the computer and is not within the computer's programmed specifications, "secondary" programs are activated by the computer to strive to protect the transmission from damage the improper sensor signal might cause to occur.
In other words, the computer is always expecting certain signal values from certain sensors i.e. the temperature sensor, the speed sensor, the throttle position sensor, etc. As long as these signals are what it would normally expect for the conditions and is normal based on all the other signals it is receiving from other sensors, it acts normally and accordingly.
If the computer, all of a sudden, receives some crazy signal from one of the sensors that is out of the normal range expected from this sensor, it will go to "emergency" or "secondary" measures........cont
Old Apr 6, 2004
Titleist71's Avatar
sounds like you may have had a limp biscut for a minute there.......lol.
Old Apr 16, 2004
civichxtreme's Avatar
civichxtreme is an unknown quantity at this point
My 01 hX did that and hasnt run since it wont even start just be happy your not in my shoes
Old Apr 22, 2004
CivicDuty's Avatar
CivicDuty is an unknown quantity at this point
My car was losing power, then it would come back again and be fine for weeks. Engine light never came on, so no code to read until finally one day it almost died completely. The car was miss firing like crazy, bucking and popping. Then the engine light came on so I took it to the dealer.
Long story short, there was a wire going to the MAP sensor (yellow) that somehow got a nick in it, corroded and broke. The engine light never came on until the wire was almost separated completely. Cost me $40 bucks for the diagnostic and wire repair, but its all fixed and running really good.
My advise is to look for any bad connections, loose wires or vacuum hoses. It could be that simple!
Old Apr 25, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
check ur oil. it sounds stupid but the gsr motors do that if u run too low on oil to protect it. just a shot in the dark.
Old Apr 28, 2004
ECU problem mine did that so i said screw it and swapped for an 02 ex engine the new engine is doing the same thing im going and picking up a new ecu tomorrow
solarpunk70
Apr 12, 2016 11:43 AM
raymondxcho
Sep 29, 2015 09:00 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
Bricoleur
Sep 9, 2015 12:30 PM
99BoostedSi
Sep 7, 2015 04:49 PM
