How many miles from OEM Pads?
Old Mar 17, 2004
conspiracy90's Avatar
conspiracy90 is an unknown quantity at this point
Hi everyone,
just curious in knowing how many miles your oem pads lasted. I had to replace mine at 14000 miles. Is this normal considering that i don't usually race my car?
Oh don't forget to post your pads mileage.
Thanks.
Old Mar 18, 2004
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
much depends on how you drive - if you brake harder or tend to ride the brake pedal..they will wear quicker.
I have a 2k1 coupe with original pads - 25k miles and also a 98 sedan, original pads replaced at just over 50k miles.
Old Mar 18, 2004
Civicly02's Avatar
i replaced mine at 10000 miles
Old Mar 18, 2004
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
i replaced mine at 49k and they had about 1/3 life left. i have a manual though and downshift alot. they didn't need to be replaced but i bought aftermarket pads and rotors.
Old Mar 18, 2004
Zzyzx's Avatar
Autocross Junky
65,000, before I switched to my Porterfields (for specific reasons) I could have gotten anoher 10 out of the pads and 30 out of the shoes, easily. Of course I do a lot of Freeway driving.
Old Mar 20, 2004
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
I replaced mine at 24,000. granted they had a little bit of life left...
Did you actually get to see the old pads, or did someone just say you needed new brakes?
Cause unless you drive the **** out of your car, they should last you minimum of 50,000 miles.
http://www.7thgencivic.com/forums/sh...62#post1866062
go there to see the status of my brakes after 24,000 miles of fairly hard driving.
Old Mar 20, 2004
bullseye's Avatar
bullseye is an unknown quantity at this point
My originals are still on the car at 90,000+ miles - lot of highway miles!
Old Mar 21, 2004
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
i changed my fronts at 89k, rear are still orriginal, and now i am at 118k
Old Mar 22, 2004
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
changed fronts at 36000
switched to brembo blanks / porterfield RS4 (i think)
rears are still stock and untouched.
Old Mar 25, 2004
dru106's Avatar
ThE CoRRupToR
22k miles and still going strong......
Old Mar 26, 2004
streetglower's Avatar
I have seen a guy at a brake shop in there getting his shocks looked at and he had over 130,000 with all the original brake ****. He only drove his car on the freeway, said he only brakes like 5 times a day. crazy **** if you ask me.
Old Mar 29, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
i have only 12,000km on my car and the dealer told me that there's only 60% of the front pads left...
i dont brake hard but i brake early and gently so i guess i sorta ride the brake
Old Mar 31, 2004
Aznnp77's Avatar
All Show No Go Sedan
Aznnp77 will become famous soon enoughAznnp77 will become famous soon enough
I changed one pair at 18k miles, then another at 28k, then another at 32, then another at 42k
Old Apr 1, 2004
cryption's Avatar
2003 Nissan Frontier
3rd set after 22k .... but i drive really hard
Old Apr 5, 2004
clean2k1civ's Avatar
clean2k1civ is an unknown quantity at this point
i have a 2k1 standard , mine lasted til 36000..... depends on the driver and whether its an auto or standard
Old Apr 6, 2004
NoFriends's Avatar
I like ruining your threads.
Just replaced mine at 23500 and had to have the rotors milled due to warping.
Old Apr 7, 2004
SUPERFLY's Avatar
SUPERFLY is an unknown quantity at this point
Mine have more than 53 000 milles and still going... Replacing soon with KVR Performance cross-drilled rotors and semi-carbon pads.
Old Apr 7, 2004
Wow. You are getting lot of miles from your pads! Did you guys do any break-in when the pads were installed?
Old May 28, 2004
italginny's Avatar
italginny is an unknown quantity at this point
im changing mine at 20000 mi , because my ebrake lift to high.
Old May 28, 2004
tom0826's Avatar
tom0826 is an unknown quantity at this point
I checked my brakes at 30K miles. The front pads looked like I could go at least another 20K. I took my rear drums off also, and the shoes had minor wear. I think I can get at least 80K from the rear shoes.
I don't really think I'm a wuss with the brakes either. I drive mostly highways, but with a lot of stop and go traffic. I try not to stomp on them really hard since it it heats up the pads and rotors too much, but I consider myself a mostly average driver, but drive aggressively at times.
Some advice- I don't wash my car unless I know the brakes have cooled off. Spraying water on hot rotors can cause warping.
Old May 28, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
I got 38,000 out of them, when I took them off, there was about 1/2 left. I saved them for track day spares just in case.
Old Jun 1, 2004
MaThMaTiKz's Avatar
MaThMaTiKz is an unknown quantity at this point
i got an auto ... LA driving .... mine lasted 17000 .... i would actually hear the screeching on the freeway and i wouldnt even be braking ... yikes
Star1967
Jun 8, 2015 04:23 AM
masongap
May 26, 2015 07:55 PM
edgenet
Apr 28, 2015 07:49 PM
bsmiley
Apr 27, 2015 01:27 PM
