Battery Dead?
Old Mar 14, 2004
XxJDMCivicxX's Avatar
Battery Dead?
This isn't for my 2k1 it's for my 92 civic hatch. My battery light has been on for about a day so I check it out with a battery tester everything seemed fine no loss of power when tested. So tonight I go to leave my friends house and the lights start dimming, so I turn them off and let the car run for about 5 minutes get back in and turn the lights on and the car stops. I boost it with my friends car drive it about 500 feet and it dies again. Would this be the battery or would it be the alternator how can I tell the difference which one is faulty?
Old Mar 14, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
to me it will sound like the alternator, because you said your battery is good, so its the alternator,
Old Mar 14, 2004
sakabatou's Avatar
sakabatou is an unknown quantity at this point
If it is a battery problem the car will not start, if the engine is not running the lights will dim and the stereo will turn off. The battery is only in use to start the car and when the engine is not running. The alternator is in use only when the engine is running. So I think you have a problem with our alternator and if your battery is old it will not hold any charge.
Old Mar 14, 2004
Yeah, and the battery light comes on when there's a charging system problem, not just dead battery. Just get the alternator tested to see if it's putting out the normal voltage.
Old Mar 14, 2004
Alright thanks guys. I'll check it out.
Old Mar 14, 2004
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
Thats your alternator dude
Old Mar 14, 2004
OniChi's Avatar
OniChi is an unknown quantity at this point
Another way to find out would be: Start your car by boosting/ or it turns on. To see if it's the battery or alternator, carefully disconnect the positive terminal. If the engine turns off then that means that the car is running off of the battery, so the alternator is shot. But if it still runs that means that the car is running off the alternator which in turn means that the alternator is shot.
Hope that helps ya out. But from what everyone is saying, it's probably the alternator.
Old Mar 14, 2004
I've heard that you can only do that on older cars....doing that to new cars can damage your ecu. I dont know if its true or not, I've just always avoided it.
pfwel1977
Sep 10, 2015 02:16 PM
jpat21
Sep 3, 2015 11:32 PM
DatGuy_Robb
Sep 3, 2015 08:08 AM
msaeger
Sep 2, 2015 08:47 AM
