Best Gauges to get for Turbo Setup?
Old Mar 11, 2004
canadian2k1si's Avatar
canadian2k1si is on a distinguished road
Hey everyone,
I am in the process of acquiring 5 gauges for my future turbo setup. 2 in a console gauge cluster & 3 in a pillar one.
Electrical gauges is the way I will be going, but I am having trouble deciding what ones to get. I am getting AutoMeter Carbon fiber of course.
I think I deffinatly need a Boost Gauge & a Oil Pressure & an Oil Temp.
But for the other 2... what should I get??
- Air Fuel Ratio ??
- Water Temp ??
- Fuel Pressure ??
- Tranny Temp ??
- Others ??
And what should the two in front of me on the console be (what will I be watching most besides my Boost)?
Thanks for the help.
Old Mar 11, 2004
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
I'd say you'd b e watching your boost and a/f the most.
You don't really need SOOO many gauges. But if that's whatcha want, I'd recommend an exhaust temp. gauge. And for the a/f, if you can afford it, I'd recommend a wideband before a narrow band. But the narrow bands are still a good thing to have if you can't afford the wideband.
Are you converting to a return fuel system? If so...then your fuel pressure gauge is usually located near the FPR and not in cabin and these are usually used for tuning purposes.
I still think 5 gauges is a bit much to have in the car...unless you're planning on making some serious power.
Old Mar 11, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
More power to you! I wanted like 50 different guages in my car at one point..
Sorry, I think gauges are sexy.
A/F, Pyrometer(EGT), Oil Pressure, Boost/Vac, and Tranny temp(if automatic), otherwise Fuel Pressure
Old Mar 11, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
Boost, EGT, and fuel pressure are the most important of any gauges. Then oil pressure and temperature. EGT and fuel pressure will tell you when you're about to blow your motor, A/F ratio gauges are useless unless they are hooked to a wideband o2 sensor/controller, and are really nothing more than pretty flashing lights.
Old Mar 11, 2004
SpdRcrChk's Avatar
BOOST JUNKY
Not everyone can afford a wideband....even though, as I've mentioned before, they're the most accurate.
But a narrowband a/f gauge will still tell you if you've managed to run lean. I've experienced this before and the autometer a/f gauge has indicated "lean" to me.
Better safe than sorry.
Old Mar 11, 2004
First to spool
This is true.. but from my experience, the Autometer a/f ratio gauge at least is very slow to react and very inaccurate. I've got a wideband controller/gauge combo in the Civic now, and for a while ran the Autometer hooked up to the stock o2 sensor and the wideband display right next to it for comparison, and the Autometer lagged behind by as much as 3 seconds, and many times showed lean when it was actually rich and vice versa. My stock o2 sensor only had 5k miles on it at the time, so I don't think the problem was related to the sensor itself.
While the Autometer gauge may be a help, I'd hate for someone to be lulled into a false sense of security and their engine be damaged.
Old Mar 11, 2004
SpdRcrChk's Avatar
BOOST JUNKY
You're absolutely right. If only we could all afford a wideband!!
The delay you speak of is informative....and I definitely think that should be taken into consideration on all accounts.
Old Mar 11, 2004
cdub604's Avatar
cdub604 is an unknown quantity at this point
how often do you read the egt gauge? and if your using nitrous is it actually helpful as well, or another a/f sorta waste?
Old Mar 11, 2004
Wow, thanks for all the advice, I have an auto by the way, and in terme of power, I am getting the first D17 Built block from DH-Racing, with the ported head & Custom IM & billet TB, the full jobbie, running 20 psi I should get somewheres arouns 400+ Whp, so I need some pretty wicked gauges to prevent my **** from breakin. Should I stick with autoMeter, or doa better brand, anny suggestions?
Well anyway, I just got home from the bar with my girl & she is wanting some sex, so I gotta satisfy her, but I had to see what you all had to say before I gave her the pleasure.
Thanks
Old Mar 12, 2004
SpdRcrChk's Avatar
BOOST JUNKY
I'd like to see dyno proof of that 400whp if it happens.
Old Mar 12, 2004
SpdRcrChk's Avatar
BOOST JUNKY
Actually I'd like to see dyno sheets and time slips period. Very few boosted people have posted anything.
Old Mar 12, 2004
Well I deffinatly plan on getting this dyno tuned when I drive into Houston later.
Old Mar 12, 2004
EnProceso's Avatar
1.fuel pressure
2.oil pressure
3.oil temp.
4.boost
5.tranny temp (if you have a AT) or egt
HondaGuy7
Feb 22, 2016 01:00 PM
Klame9420
Sep 18, 2015 12:37 PM
srtlat
Sep 17, 2015 11:02 PM
