signal tappin...
signal tappin...
after figuring out the basics of the VTEC light (ie tapping a line to monitor the signal via a LED) i was wondering if there are any other electiral lines from the ECU to tap and monitor, just to tinker...
is there a seperate signal line from the ecu to the engine that tells it to cut off the fuel (ie tapping it would make a light that comes on whenever the revlimiter, for example, is hit)
how bout rpm levels (a ghetto shift light)
get what i mean??? any other ideas are appreciated.
There is an rpm wire, but it probably won't work for a shift light. Just get a tach for that. You can't really monitor anything with a light. Just buy a VAFCII and you get everything. rpms, vtec, battery, etc.
i have just a shift light and i tapped into this one wire in the engine near the passenger headlight. check out my memebrs rides for pics of the shift light. it was a very easy install.
Crazygrlinak
Oct 8, 2015 05:06 PM
sesi
Oct 1, 2015 02:03 PM
meicalnissyen
Sep 25, 2015 12:12 AM
Touge
Sep 23, 2015 11:19 PM
Touge
Ottawa
Sep 23, 2015 11:14 PM
