how do i get my cam gear off?
Old Feb 25, 2004
jonny9508's Avatar
jonny9508 is an unknown quantity at this point
Question how do i get my cam gear off?
how do i get my cam gear off? I have already took off the plastic cover. Everytime i try to turn the stock gear it just moves. And before i put on the aem gear it has to beset at 0 then adv or retard once it on. right?
Old Feb 25, 2004
sakabatou's Avatar
sakabatou is an unknown quantity at this point
You will have to set your timing to TDC. You will have to remove your timing belt of the cam gear. The problem in removing your timing belt is that it will move your cam timing. Be verry care full. If your timing is off you will bend valves. Ask someone that has done a timing belt on our cars if the cam moves when you remove the timing belt. Take off the bolt that holds the cam gear and their is a key that holds the cam gear and cam together. Be care full in removing the cam gear because the key just falls off. the key is like a small pice of metal.
Old Feb 26, 2004
jonny9508's Avatar
what is tdc? Top dead center? where is that. on the cam gear has up on it that would be tdc?
Old Feb 26, 2004
b18c1boy's Avatar
b18c1boy is an unknown quantity at this point
look on your factory gear it will say top. make sure that is at the top in the middle. if the car is jacked up, try lowering it to the ground. that should stop it. also make sure car is in gear. or you can do this. take off left front wheel. you will see two pop rivets on the inside fenderwell near the engine compartment. take those off and peel back. you will see a bolt on the crank pulley. its a 19mm. i would advise using a deep well six point socket. 12 points tend to round off nuts. use a extension and a ratchet or breaker bar to hold that bolt still. engine cant turn if crank won't right. mark your belt at tdc. make sure aem gear is at 0. put it on. to adjust your new cam gear. loosen the three bolts and turn that crank bolt. it will adjust your timing. i would not recommend any more than 6 either way. and 6 would probably be the extreme i would go. 2-4 is probably better. also you must run premium now or it will knock. wont notice much difference without aftermarket cam. make sure you have proper torque on the three bolts on the gear. i just putt mine in like 2 mos ago. so its pretty fresh in my memory. have fun, be careful, and good luck.
Old Feb 26, 2004
JDog2001CivicEX's Avatar
JDog2001CivicEX is an unknown quantity at this point
If you don't know what top Dead Center is, take it to a shop, i can almost guarntee that something is going to get messed up
Old Feb 26, 2004
Anotherslo1's Avatar
Anotherslo1 is an unknown quantity at this point
When you have your TDC mark the timing belt, maybe with a little sharpe. This way when you put the timing belt back on , you can match the exact grooves with that of the cam to ensure timing is right.
Nevermind... B18C1Boy already said this.
Old Feb 28, 2004
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
i agree
Old Feb 28, 2004
Drivetofast's Avatar
Supercharged k20a3
Drivetofast is an unknown quantity at this point
even if you know how to make sure the timing stays the same you still havto get that bolt off and the only good way to get it off is to use an inpact wrech and i dought you have one or a conpresor to run it so work on geting or using one before you worry about the other stuff.
Old Feb 28, 2004
b18c1boy's Avatar
you dont need an impact. i just did my cam gear 2 mos ago. it will come off. just make sure you are going the right way. lefty loosey, righty tightey.
Old Feb 28, 2004
bickford05's Avatar
bickford05 is an unknown quantity at this point
yeah you dont need a impact. before you take the belt off, make sure you mark on the belt where tdc is. get the mark on the pully straight up, and upt a mark on the belt. that way when you put it back on you know exactaly which tooth the belt goes on.
Old Feb 29, 2004
jonny9508's Avatar
I got it off. And put back on. I forgot to tighten up the allen screws in the back that hold the bass piece on so it make a funny nosie. but that is for another day.
nirvanaguy
25
Oct 26, 2017 07:26 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
tommycanada
Sep 5, 2015 04:59 PM
WaryDriver
Aug 16, 2015 11:22 AM
Ccoop87
Jul 9, 2015 03:26 PM
