need help on racing seat install
i just bought 2 after market seat which came with slider. i search forums, but didn't find much about seat swap. anyway, i run into 2 problem............
1st bracks????
i took out the passager seat and unplug the wires. since my new seats only came with slider. do i need new brackets? i am thinking custom make. which one will be better??????? if i need new brackets, where could i buy them for cheap??????
2nd seat belt??????
i disconnet the seat belt buckle from my stock passager seat. i have NO IDEA how could i bolt on to my new seat...... what did you guys do.
3rd posting pic on forums
i took a few pictures but i have no idea how to post it. can anyone help.
i really hope that someone could help me on this. i am really looking forward to have to in my car. thanks people.................[
1st bracks????
2nd seat belt??????
go to carxpressions.com and buy some brackets, its worth it...they're like 30-35 bucks a piece...what kind of seats did u buy, my tenzo's came with a spot to mount the oem seatbelt , but i didnt hook it up, i just plugged everything back in with the oem seat belt buckle hiding under the seat where it cant be seen
what did you guys do about the airbag sensor wire?? i know if you run it without connecting it, it will throw a airbag code. or is there someway to bypass it
you need some universal brackets like he said. make sure to disconnect wires under the seat , than once you have your seats pulled out unbolt the stock seatbelt holders bolt them on. In reality its very very easy to instal new seats.
Almost if not as easy as an air intake.
ok thanks guys. i guess i have to order brackets. but i still ahve no idea how to mount the seat belt
also, is the bracket selling at carxpressions.com universal? will my seats able to bolt on them?????? thanks a lot guys
okay for the seat belt, you can directly unbolt it from your current seats.
very easy be carefully doing this becuase that long black shaft part says explosive
. anways once you get your brackets you might need to bend the tip just a little on the part that inserts into the bracket so you can get a tight fit.
I just bent it slightly on the cement than torque it in. note: nothing fits like it should with aftermarket parts ever!
just make sure bracket says universal or you can order a pair through tenzo. They are extremely cheap.
Like I said remember only four bolts and 2 plugs in removing the seat.
Remove plugs under the seat first. They can be reused with your buckets so your SRS light doesnt go on.
. anways once you get your brackets you might need to bend the tip just a little on the part that inserts into the bracket so you can get a tight fit.I just bent it slightly on the cement than torque it in. note: nothing fits like it should with aftermarket parts ever!
thank you very much WhiteCastle. i know what i am doing now. now i am want to know if the tenzo selling at carxpression.com are universal. i just email them. hopefully i will get an answer soon. thank you very much everyone
Touge
Jun 18, 2015 11:44 PM
Supramk3
Jun 11, 2015 11:13 AM
reqy
Jun 1, 2015 07:05 AM
