How tight should I torque 5 bolts such as alternator, transmission....
Old Feb 7, 2004
civic02ex's Avatar
got banned
civic02ex is an unknown quantity at this point
Later on today I thought about installing my grounding kit and as some of you may know the grounding kit is going to 5 main points which I will remove one bolt from the alternator, transmission, valve cover, radiator, and thermostat ground bolt.
Does anyone know the torque specs of how tight I should re-tighten the bolts once I lay the ground terminal under them? Any help would be greatly appreciated. Thanks!
Old Feb 7, 2004
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
normally most bolt on items are supposed to be torqued to 33lbs/torque. but i just tighten them as hard as i can and its close to 33lbs./torgue
Injen
EdGasket
40
Nov 27, 2015 11:11 AM
cukaracha
30
Jul 26, 2015 12:01 PM
breanna_17
Jul 21, 2015 04:01 PM
hoofboy
Jul 17, 2015 04:27 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
