Oil Question
Old Feb 1, 2004
NYTA747's Avatar
NYTA747 is an unknown quantity at this point
Lightbulb Oil Question
Does really matter to put 10w30 oil instead of 5w30 which honda deler suggest? for oil change
Old Feb 2, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
honda suggests 5w20...it says that right on the cap
Old Feb 2, 2004
flotsamm's Avatar
Stick with the 5w-xx oils. 10w is to thick, especially in colder climates so the oil wont flow as well.
Old Feb 2, 2004
02civicricer's Avatar
The Rice Machine
02civicricer is on a distinguished road
yea...i agree with Civic_Racer9...since Honda reccomends 5w20 you should just stick with it
Old Feb 2, 2004
bickford05's Avatar
bickford05 is an unknown quantity at this point
I swiched to 5w-30 moble1 because I couldnt find the 5w-20
5w-30 is thin... almost as thin as 5w-20
Old Feb 2, 2004
robbclark1's Avatar
Retired suspension supermod.
not it does not matter. If you are in colder weather, stick to lighter oils. If in variable weather, you might want to look into 5w30 or 10w30. If running turbo, you need thicker oil. I mean you can run 0w-30 and be fine.
Old Feb 2, 2004
gipperkid's Avatar
gipperkid is an unknown quantity at this point
I just run the synthetic 5w-30. Works fine for me and the engine runs good with it.
Old Feb 2, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
I run amsoil 0w-30 in my civic. OEM Filter with an oil cooler and a moroso 3qt oil accumulator. Total capacity is about 8qt. Honestly, a 5w20 is a waste of time trying to find, run a 5w30 because you can get it, or order alot in bulk for cheap. Oil change is about $80.
Old Feb 2, 2004
Philip's Avatar
Philip is an unknown quantity at this point
Royal Purple or Mobil 1....Royal purple 5W20 Mobil 1 0W-20
Old Feb 2, 2004
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
Amsiol is the best choces...but it does not matter...
remember our cars ar "green Cars" ULEV
5W20 helps have cleaner emmisions..thats all
Old Feb 2, 2004
The Rice Machine
REALLY??...i get a topped off (usually 4-5 bottles of it) 5w-20 genuine honda oil and oil filter for $20flat CDN.
Old Feb 2, 2004
czechcivic's Avatar
czechcivic is an unknown quantity at this point
I keep hearing about royal purple.....Is it really worth it???????Is there a somewhat noticable difference???????????
Old Feb 2, 2004
SlammedBlueEM2's Avatar
All Eyes On Z
5w-20 = too thin for my thick blood for driving.
Old Feb 3, 2004
Flashlightboy's Avatar
Flashlightboy is an unknown quantity at this point
If I may add to the discussion.
I was, to some degree, reluectant to use 5-20 oils but I've seen enough used oil analysis to come to the conclusion that these oils are worthy of use.
Remember that this weight is recommended by Ford in heavy duty, hauling V-8s and V-10s which are putting a lot of strain on motors. The UOAs show that these thinner oils are doing very well and aren't breaking down. The Honda engines are running at higher RPMs but hauling a heavy horse trailer up and down mountains hasn't broken the 5-20 oils.
I think that the manufacturers know that 5-20 is thin and because of this, they add a very robust additive package that more than makes up for the lighter weight. Honda seems to have taken the approach that quicker flowing, but thinner oil, is better than thicker oil that doesn't circulate as fast.
Most oils shear down with use within relatively few miles but the 5-20 oils contain such a hearty additive package that they remain solidly within grade. Even Mobil 1 5-30 shears down to a 25 type oil but their 0-20 stays a 20; it doesn't turn into a 15W oil.
If you're running all out with NOS and hit redline all the time then I'd recommend a good 5-30 such as Redline, Amsoil, RP, Germal Castrol, M1 or perhaps even the new M1R.
Me? I'm running Germal Castrol in my Exploder and I have a brand new case of Redline 5-20 that goes in the Civic.
Old Feb 3, 2004
Philip's Avatar
Yo, Bro this stuff is so good...you would probally wanna drink it. the first time i used it over 0W-20 Mobil 1 Syn. (I am runnin 5W-20 Royal Purple) I felt a little difference in my MPG....and this stuff is not call Royal PURPLE for no reason; the oil it self is the color....you guess it right Purple.
Tedverseti
Apr 23, 2020 01:45 PM
RIPSAW
Nov 6, 2015 04:36 AM
Red_Chaos1
Jun 21, 2015 01:12 AM
amrhamed
Jun 1, 2015 08:08 AM
viper775
Dec 9, 2001 10:52 PM
