K20A3 to a K20A2
Old Jan 28, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
K20A3 to a K20A2
Hey guys maybe you guys can help me...okay I understand there's a K20A3 (base RSX and SI motor) and there's the K20A2 (Type S motor)...bout of these motors are dual cam and 2.0L...whats the difference really between these two motors...how do you transform a K20A3 to a REAL LEGIT K20A2 (REAL TYPE S MOTOR)...please help...looking to make this transformation if possible.
Thanx
Old Jan 28, 2004
Jodster's Avatar
Post Whore General
Your better off buying a K20A2 motor. The A3 has a lower CP and different head. And the K20A2 has Vtec on both cams. To make a K20A3 "into" a K20A2, you need to buy the K20A2 tranny, ECU, complete head, pistons, rods, crank, and Ect. Then put it all into the A3. So in the end, you would only be using the A3 block. LOL Don't waste your time or money. Get the K20A2.
Old Jan 28, 2004
JetBlu01's Avatar
New Member
thanx dawg...preciate all the info...well anyone out there with a K20A2 or know where I can find one...HEEEELLLLLLLLLLLLLLLLLLLLP!!
Old Jan 28, 2004
Jodster's Avatar
Post Whore General
Check out car-parts.com You can find motors there. Just search for RSX engine.
Off topic questions for you. I really like your R33 kit. Is your Urethane of Fiberglass? Looks like its urethanne cause of the sagging in the front grill. Where did you get it? How is the fit of the kit? Like I said, looks really good man. Thanks.
Old Jan 28, 2004
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
Dont forget you can always get a K20A wich is 220 ponies!
http://www.naganojapanese.com/shop_online_honda.html
Old Jan 28, 2004
civicvtec1ps's Avatar
Search and Learn
K20a for N/A setup only.
K20a3 is perfectly fine. Just do k20a2 Headswap or turbo.
Hybrid EP K20A3 block/tranny and A2 head, K20A2 ECU (stock), 310cc injectors, 64mm TB
Hondata HSG, ES inserts, AEM CAI/DC Header/Megan high-flow cat/2.25" midpipe (crush)
SAE dyno #'s: 167whp 127.9tq (9.8:1 comp)
K20a3 is good for Turbo.
EP3 on the dyno at SFP. It produced 297.1whp and 245 ft.lbs of torque at 9.8 psi with 93 octane, 19" wheels, and catalytic converter. Rev limit has been raised to 8200 and runs perfect with no CEL
Cybernation Stage I Turbo Kit
Thermal Stealth 2.25" CatBack
ES Motor Mount Inserts
other stuff that is irrelivant on a dyno power run
Results:
Max HP: 266.8
Max TQ: 215.4
Old Jan 28, 2004
kjgracing's Avatar
you can see whats new for those engines here
http://www.jacksonracing.com/pages/partsnew.html
Old Jan 30, 2004
marc-111's Avatar
marc-111 is an unknown quantity at this point
question guys, how many vtec point does the new K series engine have? beacause my 7thgen sohc civic (in the philippines / see link below to belive me) has a 3 stage vtec on it and i want to install a VAFC 2 in it, MAYBE i could pattern it to the i-vtec IF it is also a 3 stage vtec
thnx!
LINK==>> http://hondakal.com/civic_tech_specs.htm
Old Jan 30, 2004
Hawk's Avatar
You boost, I-VTEC
well the difference between the I-VTEC and normal VTEC is the I-VTEC has VTC (variable timing control). Basically the I-VTEC can adjust the timing on the cam up to 30 degrees in either direction based on weather it needs economy or more power. So i'm gonna say its impossible to make your motors VTEC function like the I-VTEC.
Old Jan 30, 2004
JetBlu01's Avatar
New Member
sorry but what does all of this have to do with converting a K20A3 to a K20A2...c'mon guys let me know...lets try to stay on topic please...
Old Jan 30, 2004
Hawk's Avatar
You boost, I-VTEC
converting a k20a3 to a k20a2 would wind up costing you as much as it would to just buy a k20a2. whats different is as follows:
Entire head
Intake Manifold
Pistons
ECU
Trans
I'm sure there are more, but thats the main differences i know of.
Basically the only thing you'd be using is the a3 block like Jodster said.
It'd be to expensive and basically pointless unless the k20a3 was given to you, then you'd still have to buy all those parts, which would get really expensive.
My $0.02 just buy a k20a2.
Damn i should be the swap mod or something
Old Jan 30, 2004
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
swap mod huh hawk?
ya...you and me both.
People if you really want to learn about the K20 and all its glorry, sign up on clubrsx, and on honda-tech and just start searching and reading. Its no secret.
Jodster
Engine Swaps
35
Oct 22, 2003 10:16 AM
vivid_BLUE
Bolt-on Engine Performance
Sep 29, 2003 02:57 AM
hothondacivic02
Jul 16, 2003 05:33 PM
Player1
Jun 14, 2003 04:31 AM
North Cali
16
Mar 22, 2003 06:13 PM
