B&G problem NOT LOW ENOUGH
Old Jan 24, 2004
Elite's Avatar
Elite is an unknown quantity at this point
B&G problem I've got here. Well my B&G's are dropped all the way in the back, which are fine, they are no gaps whatsoever, but I expected them to tuck? which they didn't they are fine, but I think they are supposed to be dropped 3.5 in the back? now I have stock firestone tires, and the BIG PROBLEM is the front has a 1 finger gap in the front I also have a 02, with the 02 bearings, no noises when turning anymore, I used to have ground controls and they dropped at least 1 finger tucked inside. which is the way I want it. I called B&G and I told them the problem they told me that I shouldn't have a problem but he also mentioned that he has seen other people with B&G and they can't even drive they car dropped all the way. ALL coilovers are dropped all the way, and steering wheel is to the left a little but tires run straight if I let go, maybe to the right sometimes.
Old Jan 24, 2004
Elite's Avatar
It also looks like that the 01 upper mounts will go in further thant he 02, with the bearing that makes another .5 inches I believe. I think thats the problem but I'm not too sure.
Old Jan 24, 2004
Elite's Avatar
Old Jan 25, 2004
slicksivik's Avatar
arent they made for 01 civics, not 02
Old Jan 25, 2004
civicvtec1ps's Avatar
Search and Learn
Doesn't matter.
Same identical suspension.
I am not sure whats the problem might be. Try 01 upepr mounts bearings.
Old Jan 26, 2004
clownprince's Avatar
Ricerus Maximus
I'm not sure what the problem is, but on my 01 when I had the DropZone sleeved coilovers I couldn't tuck in the rear, but I could the front. Now with my Neuspeed race I'm tucking in the rear and only have about a 1 finger gap (if that) in the front, and I'm sure the springs will settle more as time goes on.
Old Jan 29, 2004
Elite's Avatar
just three comments?!?! I was expecing a lot more I havn't got the front upper mounts and I did add the bearing for the 02 civic
Old Jan 29, 2004
VNlilMAN's Avatar
The Standard One
thats weird.. maybe rjwsck(something like that ) can help you.. Maybe you got the ep3 application? I know their spring rates are stiffer. Or maybe something was installed wrong?
Old Jan 29, 2004
Elite's Avatar
nothing was installed wrong I helped out my mechanic I will take a look at the box right now.
Old Jan 29, 2004
sspem2's Avatar
em2
i got B+g with 18's and i got my front all the way dropped and im tucking. i got perfect alignment to so all 4 tires are straight and im tuckin on all 4's. riley aka rijowysock has 19's and hes tucking like the whole tire. i saw it in person. get an aligment then your tires will be straight then u mite be tucking cuz i am.
Old Jan 29, 2004
Elite's Avatar
It says on the sticker that the coilover part number is GF.28.012 I called B&G and they told me it was for the new honda civics, BTW I bought them from circa-x
Old Jan 29, 2004
Elite's Avatar
I have stock tires right now
Old Jan 29, 2004
VNlilMAN's Avatar
The Standard One
it shouldnt matter if the alignment is off or not, it should tuck regardless.
Old Jan 29, 2004
sspem2's Avatar
em2
well no when u lower ur car ur tires get crooked right? well he didnt get an alignment so he mite not be tucking cuz of that. get ur tires straight then you will. you see what im trying to say vnlilman? i know ur the suspension king around here but u know where im comin from?
Old Jan 29, 2004
Elite's Avatar
Im posting pictures, the front is the first one and the back is the second one, I only have rear spc camber kit set where I want it, and both are dropped all the way.
Old Jan 29, 2004
sspem2's Avatar
em2
all my 4 tires 215-35-18 look like ur 2nd pic. im tuckin all around just like that.
Old Jan 29, 2004
VNlilMAN's Avatar
The Standard One
ya i know what your trying to say but if the tires were crooked, they would atleast sit on the fender lips. But ya since he's dropped all the way and its not even doing that then an alignment isnt going to fix anything. Well unless if i'm misunderstanding.
Old Jan 29, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
well.. i have b&g too and i have them almost all the way down.. i could probally spin them 2 more notches down but all my tires are tucked already.. i have perfect alignment etc...
i duno if this apply's.. BUT.. i put my stock tire on last week when i blew a tire out... WELL... the car sits higher on the stock wheel... like theres no finger gap with my 18's. but with the stock i get like a full finger gap .
if your car isnt going that low then its gotta be the front oem bearing/mounts cause i have an 01....
i duno if u can see here.. but this is perfect alignment and no finger gap.. sits about 1mm on the tire all around
Old Jan 29, 2004
Elite's Avatar
yeah I kinda figured out that because the mounts go inside the metal bearing of the B&G suspension compaired to the 02' they sit on top of the metal bearing and the bearing of the 02 ads another .5 inches
Old Jan 29, 2004
Elite's Avatar
all I'm worried about is the front because I have the type r lip and I wanna slam my car.
Old Jan 31, 2004
Elite's Avatar
usajags84
May 10, 2015 08:11 AM
jakeconnor
May 5, 2015 07:30 AM
dooner24
Apr 14, 2015 07:51 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
