oil pressure dropping part 2
Old Jan 22, 2004
Goku's Avatar
Goku is an unknown quantity at this point
Angry oil pressure dropping part 2
okay i know you all read about my oil pressure and everyone said it shoudl be around 80-90 psi at fukk throtal but its only at like 65-70 now what shoudl i do what coudl be the problem i knwo it has something to do with the VTEC becasue of the p1259 code so does anyone know where there problem might lay someone pelase help becuase i don't want to drive my car and **** it up thanks please please please help me
Old Jan 22, 2004
Macfay's Avatar
Macfay is an unknown quantity at this point
how often do you change the engine oil?
I read somewhere that if the oil pressure dropping, that means you have to change the oil....
Old Jan 22, 2004
Goku's Avatar
i just changed it not that long ago i think there is a pressure leak but i dont' know becasue it will go form like 110 psi then when VETC starts to kick it drops to liek 80 then when it gets a little warmer it drops to 70psi then it won't go up and i just changed the oil like 1000 miles if that and im running a 5w30 so someone has to knwo what the hell is goign on please help
Old Jan 22, 2004
djmota's Avatar
take it to the dealer. They will have to run a bunch of tests with special tools that you probably don't have to figure it out. The vtec code may be because of the low oil pressure, or it or a component of it may be the cause of it.
before you take it in change the oil and filter to the proper wieght 5w-20 so they don't blame you.
Old Jan 22, 2004
Goku's Avatar
the honda dealer around here wants 69.95 an hour just to look at it and i had it there once already when it first started and they said nothign was wrong so i dont' knwo what to do i dont' have that kinda money to dish out do you or anyone know where it might be comming from ??????????????? or have any idea at least
Old Jan 22, 2004
cambo's Avatar
I wish I was asian
i'm guessing you're getting these readings from an oil pressure gauge you mounted in your car...
if so, what brand is your gauge? it might not be accurate at all.
Old Jan 22, 2004
Goku's Avatar
its an automeater adn its right becasue befor i got the code it read it jsut fine
Xuhme
21
Aug 7, 2023 03:40 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Supramk3
May 11, 2015 07:55 PM
crowtoo
May 11, 2015 06:50 PM
Chronic_issues
May 8, 2015 05:40 PM
