Anyone install Eibach ProKit themselves?
Old Jan 19, 2004
fo50rd's Avatar
fo50rd is an unknown quantity at this point
Question Anyone install Eibach ProKit themselves?
Hello All,
Just trying to get an idea of what I am in for. Got the springs arriving in the mail tomorrow. Plan on installing them with the stock shocks since it's only an inch drop. Anyone have a list of what to do or shouldn't do, I would be most appreciative! What tools will I need? What kind of ride should I expect? Thanks ev1!
Old Jan 19, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
i dont have eibach but i can tell u getting the rears back on is a lil tricky. i got mine back on by having someone stand on the rim and pull up on the wheelwell. and as far as the fronts just be carefull of the abs line. its not too bad of a job
Old Jan 19, 2004
dragoon's Avatar
I did it a long time ago, it wasn't so bad. It's a good idea to get a buddy to help, 2 if possible.
Old Jan 19, 2004
JayFReaZy's Avatar
Check out the DIY for spring installation here
Old Jan 19, 2004
civicvtec1ps's Avatar
Search and Learn
Tools used:
1 x OEM jack
2 x jack stands
1 x socket wrench (2 recommended-- a longer arm is a plus for better leverage/torque)
1 x 19mm deep socket (2 recommended, both don't need to be deep)
1 x 17mm socket
1 x 17mm wrench
1 x 14mm deep socket
1 x 14mm wrench
1 x 12mm socket
1 x 10mm socket (if you have ABS)
1 x socket extension arm (long and short-- you'll find uses for both throughout the install)
1 x 6mm hex wrench
1 x 5mm hex wrench
1 x needle nose pliers
1 x wire/cable cutters or sharp knife (for trimming bump stops)
1 x hammer
1 x tie rod seperator (optional)
1 x spring compressor (may be necessary when assembling the new springs)
http://www.7thgencivic.com/forums/sh...spring+install
Old Jan 19, 2004
VNlilMAN's Avatar
The Standard One
ya the back, i didnt even take off the rim... i found it easier to stand on the rim than the hub when trying to put it back on...
Old Jan 20, 2004
fo50rd's Avatar
Thanks All! Very Helpful
Old Jan 20, 2004
born2xLr8's Avatar
how much should I expect to pay If I get professionals to install springs?
Old Jan 20, 2004
clownprince's Avatar
Ricerus Maximus
$130 was what I was quoted today. Just had to get an idea of how much I'm saving by doing it myself.
I never thought about not taking off the rim on the rears, might make this next install a little easier
Old Jan 20, 2004
Civictuner04's Avatar
Civictuner04 is an unknown quantity at this point
I got my konis and eibach prokit installed for $300 so just the springs should be a little over a hundred if that. The ride is great. Ive had them for about 2 weeks and there is hardly any body roll and the ride is nice and smooth. That could be partly due to the konis but i havent experienced any bouncyness which would be due to the springs so i like them alot. NIce choice!
Old Jan 20, 2004
cdmx's Avatar
I think i remember its 40% stiffer than stock or something like that....pretty soft ride...almost like stock
Old Jan 20, 2004
IDQcivic's Avatar
IDQcivic should not be trusted
I used to have the prokit, but it blew my stock struts and wasnt low enough, just a warning to be careful so you don't block your stock struts, if they 're not already blown (they could be, because the stock struts are crap!) Anyways, the install is easy, just make sure you have enought time, tools, and light, and read they DIY's members have created on here and you should be all set. Not sure what 2K2REDCIVIC meant about the rear and standing on the rim??? never had to do that when installing springs... anyways, good luck with the install!
Old Jan 20, 2004
fo50rd's Avatar
Thanks again ev1. I'm going at it tomorrow...alone. Hopefully, no mishaps.
Old Jan 21, 2004
VNlilMAN's Avatar
The Standard One
trust me when i say its best to have atleast one other person help you especially when its your first time.
Old Jan 21, 2004
Ricerus Maximus
Definetly, the coilover install I did probably wouldn't have come out as well as it did without help. Local forums can be of great help, especially with finding experienced people to help.
Old Jan 23, 2004
I was trying to say. i didnt take off the rim and when i tryed to put the strut back on, the distance between mounting points was to close and i couldnt get the strut back in so i had a friend stand on the rimand pull up on the wheel well. i know it sounds getto but it worked!!!
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
