Cruise Control and Horn not Working. Please Advise. thx
Old Jan 14, 2004
Storm897's Avatar
Storm897 is an unknown quantity at this point
2 days ago my horn and cruise control stopped working. This weekend I will check to see if the horn (under the front bumper on the drivers side) is still receiving power and if so the horn itself will be replaced. But what could cause the cruise control to not work? Also, if the horn is working fine, what could cause the horn to not work. I looked in the Users manual and found no fuses for either the Horn or cruise control.
Thanks in advance for your help,
Oren
Old Jan 14, 2004
solar's Avatar
solar is an unknown quantity at this point
There is fuses for both the horn and cruise control, so look again, remember that you have a fuse box under the hood and under the dash. If it is a blown fuse, there must be something that caused it, like a short. If it is blown then you check if you added any accesories to your car like a Head Unit, Amp, Fog Lights etc. that might cause it.
Old Jan 14, 2004
Storm897's Avatar
Thanks for the response.
I fixed My horn. In the User's Manual on page 284 it says Fuse #7 (in the fuses located under the hood) is a small light. When I checked on the back cover of the fuse box under the hood it says fuse #7 is the horn. So I replaced it with a spare and my horn now works.
I dont see anywahere though in both the users manual and in both fuse boxes (under steering whel and under hood) where the sruise control is. Do they combine it with another fuse?
I have not added any accesories to my car other then a short shifter.
Thanks again in advance.
Oren
Old Jan 15, 2004
Storm897's Avatar
Problem fixed.
I never drove my car after replacing the fuse (#7 under the hood). It fixed my horn, AND once I drove it and tried the cruise control, ti worked. I guess cruise control and the horn attached to the same fuse.
Tedverseti
Apr 23, 2020 01:45 PM
kaashifv
Interior
Jul 27, 2015 05:28 PM
beeemerdude
Jul 23, 2015 03:53 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
