tie rod boot replacement?
Old Jan 9, 2004
Jonauto's Avatar
Jonauto is an unknown quantity at this point
how do u get those fricken tie rod boots off the tie rod? Ive tugged on it, cut it and it still wont come off? HELP
Old Jan 9, 2004
tfnaaf's Avatar
BLDNPSI Mod
I've never pulled the boot off of ours before but It possibly has a small metal crush collar built into the rubber. But they still should be fairly easy to pop off. Some cars have a small wire thats wraped around the boot where it meets the joint to hold it in place. And some have nothing at all !
Old Jan 9, 2004
Jonauto's Avatar
i got them off with the dremmel and i got one of the new ones on, but now the second one wont go on.. anyone know of any tricks to get them on?
Old Jan 9, 2004
Jonauto's Avatar
i figured out a way, use the tie rod seperator tool (one that looks like a bent fork and a bolt) to pull the boot down onto the tie rod... PRESTO
Old Jan 15, 2004
VNlilMAN's Avatar
The Standard One
you mean you put it on using the tie rod seperator?
do you think you can take it off using that as well?
Instructions on how to replace Tie Rod End boot from the Helms...
Special Tools Required
Attachment, 42mm 07QAD-P0A0100
1. Remove the boot from the tie-rod end, wipe the old grease off the ball pin
2. Pack the lower area of the ball pin with fresh Multipurpose grease.
3. Pack the interior of the new boot and lip with fresh multipurpose grease
Note these items when installing new grease:
*Keep grease off the boot mounting area and tapered section of the ball pin
*Do not allow dust, dirt, or other foreign materials to enter the boot
4. Install the new boot using the speical tool. The boot must not have a gap at the boot installation sections. After installing the boot, check the ball pin tapered section for grease contamination, and wipe it if necessary
Now anyone actually try it?
Old Jan 16, 2004
Aznnp77's Avatar
All Show No Go Sedan
Aznnp77 will become famous soon enoughAznnp77 will become famous soon enough
Safety warning. You cannot replace just the boot alone. It is specially fitted from the factory i have heard. I put it on partially, not snug fit, and had a tie rod failure which gave me a near death experience on the highway. Just a warning, I would replace the whole tie rod end.
Old Jan 16, 2004
VNlilMAN's Avatar
The Standard One
tie rod failure? what happened?
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
CarStuff
Dec 6, 2020 12:52 PM
pheaton
May 4, 2015 08:26 PM
El_Spic
Apr 23, 2015 03:14 PM
toastyghosty
37
Jun 10, 2002 01:07 AM
