Best oil or most commonly used?
Old Dec 29, 2003
Whelan's Avatar
Whelan is an unknown quantity at this point
I was going with whatever the dealership put in. But I went to my usual place and got a 5-20W full synthetic oil change. The car seemed to run a bit smoother with full synthetic.
Does anyone have any opinions on type of oil to use, full or partial synthetic? Let me know.
Old Dec 29, 2003
cdmx's Avatar
My most commonly used oil is royal purple
Your welcome for my input. I find that it runs smoother if you use 3qts of your oil of choosing and then 1qt of stp oil treatment..
Ive switched to 5w30 and switched back to 5w20 cause it didn't feel as smooth with the first switch
Old Dec 29, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
I've found the car runs better with full synthetic (Mobil 1 is all I'll dump in now). I went to 5W-30 and found the gas milage went up, the engine temp went down and the car overall seems to be working better with 30 weight. I'm using 0W-30 right now cuz its thinner for cold starts in the winter, but I don't think I'll go back to dino juice again.
Full syn is going to be better because it holds crap in suspension and gets it out of the engine rather than leaving it everywhere. There's also no carbon buildup from synthetic. The bad thing is if you have a leak, synthetic is much more likely to find it and go through it.
Old Dec 30, 2003
hondaguy2582's Avatar
hondaguy2582 is an unknown quantity at this point
use the mobil 1 0w20. Best synthetic oil for our cars, and it will increase your horse and gas mileage a bit. Makes my civic a lil peppier.
Old Dec 30, 2003
TMRakip's Avatar
TMRakip is an unknown quantity at this point
I too use Mobil 1 0W20, my car seems to like it, everything feels a little better but that's probably just a psychological effect
Old Dec 30, 2003
Dr5D's Avatar
Re: Best oil or most commonly used?
What oil did they put in? It is soo hard to find 5-20 synthetic!!!
Where can I get this royal purple stuff besides the internet?
Old Dec 30, 2003
jjj784's Avatar
jjj784 is an unknown quantity at this point
i use 5-30 mobil 1 synblend
Old Dec 30, 2003
Bellz's Avatar
Ditto on the Mobil1 0W20. It's good stuff.
Old Dec 31, 2003
mowrey1999's Avatar
mowrey1999 is an unknown quantity at this point
I have been using synthetic oils for probably 15 years and feel there far superior to regular oils , I mean if you change your oil on a regular basis with regular oil I dont think you will ever have a problem but it like running a stock air cleaner instead of a better flowing K&N , in performance applications every ounce of horsepower and reliablity is your objective so the better quality oil and the ability to lubricate consistantly is what you want,Overall in a stock car or performance application it means better mileage, performance and less internal wear or friction. I ran amsoil synthetic in my 1990 honda till it had 325,000 miles changing it every 9000 miles with a full flow filter and then sold it and the guy is still driving it without no smoke or problems, I have used mobil 1 since it is a little cheaper with great success in my toyota tacoma that has a little over 100 ,000 miles and just purchased a new civic for the wife and willl be running amsoil again in it and changing it every 7500 miles with there full flow filter,I have personally had good luck with synthetic oils and recommend it even though I have no scientific information to back it other than what I have read but I have lots of miles on my vehicles with no internal problems either in the oiling systems or major mechanical areas such as rotating assemblys ect, I just keep replacing shocks, tires, ect.
Old Jan 10, 2004
streetglower's Avatar
Re: Re: Best oil or most commonly used?
If you get 0w-20 it is the same thing as 5w-20. I read on the mobil 1 oil bottle for 0w-20 that it takes the place of 5w-20 oil for hondas. Also you can find royal purple at the dealership for about $7 to $8 a quart, or at any auto part store that stock it for about $6 a quart.
Old Jan 11, 2004
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
full syn is the way... i use mobil 1 5-30 ... best for hard driven cars i think... woiuldnt be comfy with 0 weight when im turbo'd.... i change every 2k miles.. comes out cleaner than ****...
Old Jan 11, 2004
orso's Avatar
orso is an unknown quantity at this point
mobil 1 5w-30
Old Jan 11, 2004
Hypnotik's Avatar
Hypnotik is an unknown quantity at this point
ok, im looking to switch to synthetic oil, but at my local jiffy lube it costs about $80 for mobil 1?! is this a fair price or not?
Old Jan 11, 2004
Eeeeeeh's Avatar
Eeeeeeh is an unknown quantity at this point
Mine too. It felt like it didn't rev as quickly, but it did drop my temperature. I guess I'll try out that Royal Purple.
Old Jan 11, 2004
They might be a bit too much, but you will be looking to spend $40-70 on a synthetic mobil 1, depending on where you go. Here at kwik car, a regular oil change is like $25 and to upgrade to have synthetic oil is is about $60 and to use royal purple is is $70, kinda high, but go to walmart and by Mobil 1 oil for like $4.50 a quart and a oil filter, and then change the oil your self, and you only spend about $25, instead of about $60.
Old Jan 12, 2004
no doubt man... who still pays people double - triple for oil changes,,, buy a case of hamp oil filters (they DO fit out cars, i need to order them), get a case of mobil1 (online saves you money) .. and call it a day ... oh yeah, get a magnetic drain plug (LOVE mine)... anwyas, buy in bulk and it can get down to $17-20 an oil change.. not bad...
Old Jan 12, 2004
AudioQuest's Avatar
AudioQuest is an unknown quantity at this point
As far as the synthetic oils go, it would seem that the best of the best is Amsoil. Mobil 1, Royal Purple and Red Line all make excellent oils, but indepenent tests show Amsoil lubricates just a little bit better. Be careful when using Castrol Syntec. Syntec is NOT a full synthetic - it is a Type III synthetic which means it started life out as dino juice and was changed on the molecular level to become a synthetic. I'm not sure if Valvoline, Pennzoil and Quaker State's synthetics are Type III.
Old Jan 12, 2004
draganjr's Avatar
draganjr is an unknown quantity at this point
when using royal purple, do you use 5w20 or 5w30?
Old Jan 12, 2004
you can use either, it is all about preference. Sometimes what the dealer recommends isnt always best.
Old Jan 12, 2004
2001civ's Avatar
2001civ is an unknown quantity at this point
Thats right, your welcome for his input. And you damn well better appreciate it! you're damn lucky he responded to this FREE internet site!!! you ungrateful son of a bitch.
Old Jan 12, 2004
draganjr's Avatar
What is that for?
Old Jan 12, 2004
What is that for?
yea, what the hell is that for.
Old Jan 12, 2004
robbclark1's Avatar
Retired suspension supermod.
Amsoil makes a 5w-20 which i just switched to.
Old Jan 12, 2004
AudioQuest's Avatar
The Amsoil XL-7500 5W20 is not a 100% Synthetic motor oil. It is a Type III Synthetic. Amsoil fully admits this on their website.
All of their XL-7500 motor oils are only Type III synths.
Old Jan 12, 2004
JDMTUNED01's Avatar
JDMTUNED01 is an unknown quantity at this point
Use dino oil and change it every 3000-cheap easy and effective. i dont care if sythetic is the best think since sliced bread im still not leaving any kind of oil in my cars for over 4000 miles.
Old Jan 12, 2004
mowrey1999's Avatar
I saw your reply and know changing your oil is cheap and easy, but changing it when it isnt necessary is my issue, By running synthetic I can change it a lot less and use less filters and less time under my car,If your concerned with the condition of the oil at 3000 miles have a oil analysis done to see the condition of your conventional motor oil is.It will tell you a lot about your motor and possible problems, typical oil analysis done on full synthetic not castrol syntec,which is a type III synthetic not a full synthetic ect show they can easily go 12,000 miles and still dont need changed,I never change my oil less than 7500 miles since it isnt necessary using synthetic . You will see in tests that conventional oils show signs of breakdown within 500 miles and at 2000 miles not giving much internal protection. I feel if synthetic oils werent so good most all of the racing teams wouldnt be using them .
Old Jan 12, 2004
02SilvCiv's Avatar
02SilvCiv is an unknown quantity at this point
Where can you purchase mobil1 online. i have never been able to find it online. i would really appreciate it if you could tell me.
Thanks
Old Jan 16, 2004
02SilvCiv's Avatar
BUMP. i would really like to know where i can buy this stuff online.
Old Jan 16, 2004
Just go to walmart, they have mobil on for $4.77 a quart, thats what it is here.
Old Jan 16, 2004
02SilvCiv's Avatar
Thanks, I saw that at walmart but i thought there might be someplace cheaper on the net.
Thanks Again
