Best oil or most commonly used?
Old Jan 28, 2004
  #31
pnoiracer's Avatar
pnoiracer is an unknown quantity at this point
Originally posted by streetglower
yea, what the hell is that for.
yea seriously, what the hell is that for?
Old Jan 28, 2004
  #32
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I just read through this whole entire thread and I'm confused now. So, NOT using 5w-20 won't hurt the engine at all in the long run? Because I used to use 5w30 but then someone told me that not using 5w-20 will hurt the engine later on just because of the temp changes or something? Mmm hell if I know, I'm just an installer.
Old Jun 6, 2004
  #33
Velocifero's Avatar
Velocifero is an unknown quantity at this point
Honda (as well as Ford) has switched to 5W-20 in all of their new vehicles to obtain a higher efficiency rating from the EPA. There's nothing magical of using 5W-20 in our Civics other than the very slight improvement in gas milage. 5W-30 actually provides better lubricity and shear strength which <i>should</i> result in less engine wear.
After the first few thousand miles I've switched from 5W-20 to 5W-30 and have noticed a significant decrease in engine noise at idle. Both are Amsoil, with the 5W-30 being Amsoil Series 2000 full synthetic stock.
I will probably switch to Mobil 1 5W-30 as its available to me at a lower price and because Mobil 1 is generally thinner than Amsoil at the same weight rating.
Old Jun 7, 2004
  #34
civicfrenchie's Avatar
civicfrenchie is an unknown quantity at this point
syntethic is overkill if you dont race on road courses...go for penzoil 5w20 the best dino oil out there
Old Jun 7, 2004
  #35
StealthCivic's Avatar
StealthCivic is an unknown quantity at this point
some wisdom
I agree with you frenchie.....no need for synthetic, unless you want to waste
your $$$
I use 5w20 like you, but usually Castrol GTX
Old Jun 8, 2004
  #36
SMX's Avatar
SMX
SMX is on a distinguished road
I ran Pennzoil for years, until I pulled heads and they were caked. I run nothing by synth now. Short trips around town are as tough on your oil as racing.
Old Jun 8, 2004
  #37
zen_master's Avatar
Mobil 1 (PAO) 0W20, recommended for the application of 5W20.
$30 oil change in Wal-Mart, including 4 quarts of oil and FRAM Tough Guard oil filter..
change every 3K miles, your engine will be clean and happy all the time.
Old Jun 8, 2004
  #38
draganjr's Avatar
draganjr is an unknown quantity at this point
Used Pennzoil in my Integra and after re biulding the engine, I will never go back to Pennzoil again! Just my 2 cents!
Old Jun 8, 2004
  #39
aznsensation18's Avatar
aznsensation18 is just really niceaznsensation18 is just really niceaznsensation18 is just really niceaznsensation18 is just really niceaznsensation18 is just really nice
ok...i have basically a stock 03 manual....i just did my oil change to 5w-30....if i am completely stock and i go to synthetic oil it wont fu(k **** up will it.....i am doing my next oil change so...should i just go to synthetic or stay the same?????
Old Jun 8, 2004
  #40
for you who scream against penzoil www.bobistheoilguy.com you'll see with technical proof that penzoil 5w20 with his strong additives package is pretty good for the $$$ 5w20 is a new oil with strong additives...it will not deteriorate like conventionnal 5w30...you can compare 5w20 like a semi-syntec....if you wanna throw your $$$ for peace of mind it's ok...but read on this site...you'll see...more $$$ is often better but not always...daily driving dino 5w20 more than enough
Old Jun 8, 2004
  #41
robbclark1's Avatar
Retired suspension supermod.
Blah. Yes, your engine will run fine on regular oil, but synthetic has been proven to not break down as quickly and breaks down at higher temperatures than regular oil. A lighter weight is better for summer months, a higher weight is good for winter months. You can run 0w-30, 5w-20, 5w-30, 10w-30 for non turboed engines.
Old Jun 8, 2004
  #42
I agree again....why argue against the manual we got with our civics??
Do you think the honda technicians are fools??
Read your manual. 5w-20 regular oil is the best oil for your civic and your $$$
Robb, I live in a warm climate so I run the 5w-20 year round.....
Old Jun 8, 2004
  #43
SMX's Avatar
SMX
Bobistheoilguy is a great resource. It's one of 3 or 4 I get my information from. I ain't screaming against pennzoil or other dino's. I offered a personal experience, one that is backed up by other mechanics I know. I use synth because it is a superior lubricant. Just plain fact.
Old Jun 8, 2004
  #44
robbclark1's Avatar
I don't think they are fools. But they also give guidelines for people because most people are stupid. My honda dealership would put 10w-30 when they would change mine because of my variable climate.
Old Jun 8, 2004
  #45
I agree with the fact that syntec is better...i only think that's overkill for is application...that's it...racing use = synthetic for sure...daily driving don't need imo...peace
Old Jun 8, 2004
  #46
SMX's Avatar
SMX
Actually, daily driving with lots of short trips can be as hard on your oil as racing. The additives get trashed quickly during short trips. The oil accumulates water and becomes acidic. If I were going to sell my 'vic before it turns 100k, I'd use dino and not worry. My last car ('88 accord that some of you probably "killed") clicked 240k and was clean as a whistle inside thanks to synth. This car will make it at least as far...
Old Jun 8, 2004
  #47
looking at oil analysis they do the job(5w20 dinos) at 5000 mi, if you want peace of mind do 3000 mi oil changes...by the way the oil samples that i'm talking about have been taken in cars with a lot of short trips...5w20 can't compare with others dinos cause of their additives...
Old Jun 9, 2004
  #48
Should I switch then?
I went to that bob's the oil guy site...I could harldly understand any of it though man! complicated arguin about which oil is better!
I have always used 5w-20 for my vic, but you guys got me thinkin (and that confusin bob's oil site!) of switchin to 5w-30 for better engine protection and longevity?
I change my own oil with castrol gtx 5w-20 and a purolator oil filter and I'm runnin smooth.....
Old Jun 9, 2004
  #49
Storm897's Avatar
Storm897 is an unknown quantity at this point
I to use Castrol CTX 5w-20 and Either a Purolator or Fram Filter.
An interesting quote from the bob oil guy website.
As Honda's Principal Chemist Jeff Jetter puts it, "We're so far ahead of the mpg curve that CAFE was not an issue. We meet EPA requirements easily. But we're a 'green' company and believe that the fuel economy improvement provided by 5w-20 is important.
"Also, our testing indicates that engine performance is generally improved with a lighter viscosity grade engine oil, resulting in reduced emissions during cold starts before the catalyst comes on line, when cars emit most of their pollutants...
"...Durability is not an issue either. If it were, we wouldn't recommend 5w-20."
Old Jun 9, 2004
  #50
Thanks man
Thanks Storm, I appreciate the info!
Old Jul 10, 2004
  #51
Dr5D's Avatar
Yall are talking about oil weights and stuff, but I am just using the same kind that is recommended with Mobil 1 and a Bosch filter
Old Jul 11, 2004
  #52
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
red line 5w-20 is my pick. highest shear strength of any 5w-20.. the rest barely break the bare minimum
bobs site has a wealth of info.. it is confusing at first..but youll learn.
Old Jul 17, 2004
  #53
Storm897's Avatar
I use Castrol GTX as stated but have been reading the forums over at bobistheoilguy.com and found this interesting UOA of Mobile 1 0w20. Might change to it as it seems very impresive at even 7591 on a 02 Civic SI driven hard an in Auto-X's.
http://theoildrop.server101.com/ubb/...=001506#000000
Old Jul 17, 2004
  #54
Storm897's Avatar
UOA on Castrol GTX 5W-20; 5,011 miles on oil. With 2001 Honda Civic LX, MT; 41,500 miles on unit.
http://theoildrop.server101.com/ubb/...=000213#000000
Old Jul 28, 2004
  #55
pnoyster2k1cvic's Avatar
Balut Eating Champ
aight i'm so confused with this oil change thing... I went to walmart and bought me a 5qt MOBIL 1 SUPERSYN 5W 30...
but I stopped by today in autozone and found MOBIL 1 TRIPPLE SYNTHETIC...
and MOBIL 1 FULL SYNTHETIC...
which one is it really? am suppose to use the MOBIL 1 FULL SYNTHETIC? what's the difference between the FULL SYNTHETIC, TRIPPLE SYNTHETIC AND THE SUPERSYN???
oil gurus please help me out, I'm getting my turbo installed this week and I need to get the right synthetic oil for my ride... thanks!
Old Jul 28, 2004
  #56
nivenmk1's Avatar
nivenmk1 is an unknown quantity at this point
Dumped in Mobil 1 0w20 full synth. Love the stuff, power delivery much smoother, makes the car more fun to drive.
Old Jul 28, 2004
  #57
zen_master's Avatar
u have to kick ur car, clean em, dude..
run 80-85 mph on highway...all the way....about 1000 miles after an oil change!
that'll cleannnn ur car....
Old Jul 29, 2004
  #58
Balut Eating Champ
any of you guys can answer my question?
what's the difference between the:
---Mobil 1 Full Synthetic
---Mobil 1 SuperSyn Anti Wear Full Synthetic
---Mobil 1 Tripple Synthetic...
^^^I'm using 5w 30 Mobil 1<<<I'm boosting soon, and I think 0w 20 is just to thin and light, but I'm not sure which one to get yet... Mobil 1 Full Sythetic, SuperSyn, or Tripple Synthetic
Old Jul 29, 2004
  #59
hakangunduz's Avatar
hakangunduz has a spectacular aura abouthakangunduz has a spectacular aura about
oil numbers
hello, last time I went to Japan and I saw some oil like 15-40 or 15-60 and it was soo expensive..almost 100$..how but 10w-40 use in civic? and whats the meaning of that digits?
Old Jul 29, 2004
  #60
ctx66's Avatar
[B]any of you guys can answer my question?
cant help ya, your best bet would be to ask that question here
http://theoildrop.server101.com/ubb/...?ubb=forum;f=1
