FS: K20A3 2.0L DOHC iVTEC (2003) engine & 5spd tranny SWAP in NJ. $2500 or B/O!
Originally posted by navyedoc
subframe??? ac lines, ps hoses? trade for a d17a2 + a fields vtec controller + gsr fat fives painted gunmetal w/ a polished lip??
lines/hoses, no.
trade, no.
cash, yes.
Search and Learn
Originally posted by DaCurryman
which engine is the K20A3? I know the A2 ia the RSX-S. Is the A3 from the SI? If so, what are the specs
Engine Code : K20A3
Type : In-line four, aluminum block and head
Valvetrain : DOHC, four valves per cylinder, i-VTEC variable valve timing
Displacement : 1998cc
Bore & Stroke : 86.0 mm x 86.0 mm
Compression Ratio : 9.8:1
Claimed Horsepower : 160 hp @ 6500 rpm
Claimed Torque : 132 lb-ft @ 5000 rpm
Redline : 6800 rpm
Drivetrain
Layout : Transverse front engine, front-wheel drive Transmission Gear Ratios
1 : 3.062:1
2 : 1.769:1
3 : 1.212:1
4 : 0.921:1
5 : 0.738:1
Final drive : 4.764:1
Differential : Open
how much would it cost to throw it into an 01 AUTO?
You will need new motor mounts too.
also, i think to swap from auto to 5 speed, you might need the linkage from an RSX, a civic coupe might or might not work due to the transmission being on the opposite side of the engine bay, however, you may have to mod the linkage from the RSX, the length may or may not be of a different length. if someone is REALLY interrested and needs to know that info, just contact HASport, theyll hook ya up
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
