Sponsored by:
Sponsored by: CARiD
Not your ordinary Electric supercharger...?
Old Dec 23, 2003
robbclark1's Avatar
Retired suspension supermod.
http://www.boosthead.com/product.php?id=18
What do you guys think of this thing? Not that I plan on getting one, but I just wanted you guys to see it.
Old Dec 23, 2003
Master's Avatar
Banned by Admin
I would have to see it on a car to believe it. But they do have dyno sheets, even though I can't read them to well. But until it is proven by other people putting it on their car I will think it is a waste of $2,000.
Old Dec 23, 2003
PunkingCivic's Avatar
I need TP for my bunghole
I seen that before. I don't know I would have to see it perform in person.
Old Dec 23, 2003
robbclark1's Avatar
it looks like a real blower, but instead of attaching to your pully it is run by electric batteries. hmmm...
Old Dec 23, 2003
Green Civic's Avatar
I'm weary of that product. I would have to see a person with that setup and see it run to believe it. I dont see how it works off of electricity.
Old Dec 23, 2003
bluestreak's Avatar
bluestreak is an unknown quantity at this point
if it looks too good to be true, it probably is-save another G and get a turbo
Old Dec 23, 2003
Bellz's Avatar
Here's the kicker, from their FAQ:
"Why is the ESC-400™ limited to only 15-second bursts?
The heat generated by 15KW limits the running time. So do your batteries. There is only a specific amount of stored energy available. How often do you run for over 15 seconds? If you do that on ANY car you are over 90+ MPH. Some of you may drive faster than 100 MPH on the street, but those speeds should be saved for the racetrack.
How long does it take to recharge the system?
You can recharge the batteries in a couple of minutes with a high output alternator."
The $2000 doesn't include the batteries or alternator either!
Check out this page, showing all the stuff you have to buy in addition to their electric turbo:
http://www.boosthead.com/installation_docs/doc17.htm
Nice idea, but I say get a Turbo instead.
Old Dec 23, 2003
ELaudio's Avatar
ELaudio is an unknown quantity at this point
P.O.S. I'd prefer the reliability of a nitrous system or the always-on benefit of a turbo setup.
Running a tiny supercharger off of 3 starter motors is absolutely absurd. 4-5 minutes to charge? B.S.
Old Dec 23, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
its a repost, its allready been talked about before in the "forced induction" forum....
Old Dec 23, 2003
cdmx's Avatar
Its not worth it.
Old Dec 23, 2003
cdmx's Avatar
or is it?
Old Dec 23, 2003
Zzyzx's Avatar
Autocross Junky
seems like it would work, its just replacing a Normal BLowers Belt drive with electric motors........ the theory is sound, but how much harder does the altinator have to work?
only thing I'd wonder about is all that extra weight in batteries....
Old Dec 23, 2003
robbclark1's Avatar
It says the weight is less than that of a turbo kit. Not by much maybe 10 lbs or so.
Old Dec 23, 2003
Jonauto's Avatar
Jonauto is an unknown quantity at this point
that weight is not including batteries
Old Dec 23, 2003
Dr5D's Avatar
how about the 10+ hours of install time
Old Dec 23, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
Since when is nitrous reliable?
Hmm, nah I wouldn't go for this type of "forced induction". I mean, if you save up another grand, you've got a turbo. So what's the use? But if you've got money to burn, then..
Old Dec 23, 2003
Zzyzx's Avatar
Autocross Junky
[Q] You should have invested in ported pistons and VTEC rods and a carbon fiber powerband. [/Q]
Did some one actually say that??? shall we go beat them with rubber hoses?
Old Dec 23, 2003
pheaton's Avatar
A descendant of 2k1civic.com
N/A all the way!!
Ok. . ok. . I'm kidding. . I love a turbo just as much as the next guy. .
The electric thing is a good idea, but they need to improve it. . Make it so that it can run all the time without causing a problem with recharging it and stuff like that. If they could improve the quality, meaning it's ability to always be on and always be ready to give you some HPs, then it would be sweet. Until then regular Turbo, or supercharger.
Old Dec 23, 2003
Bellz's Avatar
Building on what Pheaton said, when cars finally upgrade to the higher voltage electrical systems, we'll see a lot of improvements in electronics and anything that uses a lot of current. Car stereos for example will adapt and benefit from higher voltage. Amplifiers will also benefit from the new changes.
It will probably change the way that we install amplifiers and eliminate any possible need for caps. I'm guessing this will bring about a revolution in car stereo and possibly shrink the size of amps. I may be overreacting, but there's going to be a lot of changes very soon.
There was an article in Popular Science or Popular Mechanics this past year about the many changes that will take place with the voltage upgrade. I'll see if I can find more info.
Check out these Q&As from the FAQ about this subject:
"How will the ESC-400™ work with new production vehicles?
New cars can definitely benefit from the ESC, as the latest electrical systems usually have a higher capacity to recharge the batteries. Most new cars have an alternator rated at 100+ amps, so a replacement high output alternator may not be needed. Also, most fuel systems work well at wide-open throttle (WOT), and the ESC only operates at WOT
Will the new 42 volt systems on production cars work with the ESC-400™?
The 42V standard for automobiles starting in 2006 will make electric supercharging the wave of the future. Currect draw is reduced as voltage increases, so the higher the voltage the more power that should be available."
Come to think of it, this deserves a thread of it's own...so I started one HERE.
Old Dec 23, 2003
MatrixShark's Avatar
MatrixShark is an unknown quantity at this point
Old Dec 25, 2003
Jeremy's Iron
Yeah, actually, they did. But I got it from another forum, not this one..
cferry7
Oct 18, 2015 06:32 PM
Solo Flow
Oct 4, 2015 07:52 AM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Bruce2
Sep 27, 2015 08:45 PM
beanhead
Sep 24, 2015 12:04 PM
