Hondas anti-Roll bar confusion
Old Dec 16, 2003
Zzyzx's Avatar
Autocross Junky
ok, this is weird.
I was under the impression that the 01-02 civics specifically the EX had a 25.4mm front anti-roll bar and a 12mm rear.....
after some reasearch I've found that Honda has been screwing with the suspension each year....
01 EX (For both Coupe and Sedan)
Front 25.4mm
Rear 12mm
01 LX
Front 25.4mm
Rear (N/A)
01 HX
Front 25.4mm
Rear (N/A)
01 DX
Front 25.4mm
Rear (N/A)
02 EX Coupe....
F 25.4mm R 13MM (Honda Changed it!)
02 LX Coupe
F 25.4mm R 13MM (Added a rear bar)
02 DX Coupe
F 25.4mm R (N/A)
02 HX Coupe
F 25.4mm R (N/A)
Here is where it gets interesting,
02 EX Sedan........
F 22.2mm R 13mm
02 LX sedan
F 22.2mm R 13mm
02 DX sedan
F 22.2mm R (N/A)
whats the deal??? the sedan gets a smaller front bar in 02??
03 has very little info out.. (At least I couldn't find any)
the 04 gets screwed..
EX and LX coupes are the only ones that get anti-roll bars and they are droped to
15.9mm Front and 12mm rear wich is caried over to the sedan.
so apparently honda has yet to make up their mind on how the civic is suppose to ride like and handle like....
Old Dec 17, 2003
Flash6009's Avatar
Flash6009 is an unknown quantity at this point
I wonder why that down sized so much for the 04 vic?
That is very strange!!!!!
Old Dec 17, 2003
IronFist's Avatar
Good find! I approved your post
Very weird info, tho. I wonder what Honda's thinking was.
Old Dec 17, 2003
Drnknmnky13's Avatar
Maybe they were thinking " it's an economy car...they don't even need a sway bar...but we'll but some small ones on to keep it from being too sloppy"
Or maybe they were hitting the ganja and thought it would be funny.
Old Dec 17, 2003
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
I got the 02 ex coupe... and i think it's got the stiffest set up, but it can be a little on the harsh side (for a factory setting). I notice it the most when i drive over this road that has a bunch of hugh tree roots pushing the pavement up. I've driven my friend's ex sedan and i can definitely tell the difference in the chassis (4 cutouts for the doors) and the suspension set up.
Old Dec 17, 2003
Vinh's Avatar
HOWEVER,
2002 HONDA CIVIC HX has a 12 mm oem sway bar
here's a picture of mine
Name:	oem civic rear sway bar.jpg
Old Dec 19, 2003
slowvic's Avatar
slowvic is an unknown quantity at this point
My 03 had a 15mm front and I think 12 or 13mm in the rear. They probably decreased the size of the front bar to reduce understeer, but it had more body roll than a fat man sitting on the living room couch.
Old Dec 19, 2003
robbclark1's Avatar
Retired suspension supermod.
you got it mixed up. They reduced the size of the front bar to INCREASE understeer and DECREASE oversteer.
Old Dec 19, 2003
slowvic's Avatar
Uh, I though a bigger front bar increased understeer and a bigger rear bar increased oversteer. I could be wrong. My 27mm progress bar induces more understeer than the stock front bar did, well actually it seems like it keeps excess oversteer in check. I guess its the front and rear difference thats important. ?
Old Dec 19, 2003
Zzyzx's Avatar
Autocross Junky
^^ It depends on what honda did with the Spring rates....^^^
If Honda left the same spring rates and just downsized the Front Bar then yes you would get less understeer and more body roll, but honda probably changed the spring rates too, so who knows.
Old Dec 19, 2003
robbclark1's Avatar
yeah but you have the set of bars. If you just put the 27mm rear bar on then you would increase oversteer. Zzyzx just took his front bar off all together and has increased his oversteer.
Old Dec 19, 2003
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
sigh.... the bane of the 03 hx... NO SWAY BARS WHATSOEVER...
On a side note, I got my cusco rear upper strut bar today... YAY
Old Dec 19, 2003
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
I have an 03' EX with 16/19 combo and I think turn-in is better plus you can rotate the rear better than the stock 16/12,or13? combo it came with. However, this setup is far from balanced and I'm now thinking of going with a 25.4 front with the progress 22mm rear. The 16/12 stock setup is horrible, body roll reminiscent of my mother's old minivan. For this reason I doubt honda changed the spring rates much, if at all. Poor Renamazazo, I thought 16/12 was bad but no sway bars at all must have been hell.
Old Dec 19, 2003
CapYoda's Avatar
Escaped Convict
dont forget that they also fudged with the spring and shock rate in the 02s.. and possibly the 04s.
Old Dec 20, 2003
slowvic's Avatar
ok
Old Dec 22, 2003
opto_isolator's Avatar
may have something to do if the weights of the cars are different too - they changed / tweaked lots of things between model years, this just may be to accomodate the other changes they made, who knows....
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
BootyDo
May 7, 2015 04:46 PM
zcwagon
Apr 24, 2015 05:18 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
