Wiring of Crimestopper CS880S OEM for 2002 sedan
Hi, can anyone help me with the below connection that I have no ideas where to connect. Thanks.
1. (-)Neg. Door pin sw. (green)
-- No idea where to connect, pls advise.
2. (+)Pos. Door pin sw. (violet)
3. Parking lights 10A max (white) - to pos. or neg. of parking light ???
--PARKING LIGHTS - blue factory alarm plug *1 or to PARKING LIGHTS + red/black back of the fusebox.
Pls also confirmed for me the below connection are correct. Thanks.
1. (+)IGN switch after fuse box (yellow)
--IGNITION black/yellow + ignition harness
2. (-)Neg. Hood/Trunk Pin sw. (bule)
--TRUNK/HATCH PIN red - factory alarm plug *1
3. (-)Neg. Output for car horn (Gray)
--Not in use.
4. (+)Pos. Siren output (brown)
--To siren output came with alarm.
5. Battery after 15A fuse (red)
--12V white + ignition harness
6. (+/-) Unlock input signal (blue)
--POWER UNLOCK white/green - gray plug above drivers kick
7. (+/-) Lock input signal (green)
--POWER LOCK white/blue - gray plug above drivers kick
Attached the diagram for CS880S alarm.
--Not in use.
CarStuff
Dec 6, 2020 12:52 PM
Civic2002lx
Oct 7, 2015 09:17 AM
izdman
May 19, 2015 03:43 PM
