Wiring of Crimestopper CS880S OEM for 2002 sedan
Old Dec 9, 2003
ht380's Avatar
ht380 is an unknown quantity at this point
Hi, can anyone help me with the below connection that I have no ideas where to connect. Thanks.
1. (-)Neg. Door pin sw. (green)
-- No idea where to connect, pls advise.
2. (+)Pos. Door pin sw. (violet)
3. Parking lights 10A max (white) - to pos. or neg. of parking light ???
--PARKING LIGHTS - blue factory alarm plug *1 or to PARKING LIGHTS + red/black back of the fusebox.
Pls also confirmed for me the below connection are correct. Thanks.
1. (+)IGN switch after fuse box (yellow)
--IGNITION black/yellow + ignition harness
2. (-)Neg. Hood/Trunk Pin sw. (bule)
--TRUNK/HATCH PIN red - factory alarm plug *1
3. (-)Neg. Output for car horn (Gray)
--Not in use.
4. (+)Pos. Siren output (brown)
--To siren output came with alarm.
5. Battery after 15A fuse (red)
--12V white + ignition harness
6. (+/-) Unlock input signal (blue)
--POWER UNLOCK white/green - gray plug above drivers kick
7. (+/-) Lock input signal (green)
--POWER LOCK white/blue - gray plug above drivers kick
Attached the diagram for CS880S alarm.
File Type: pdf
Old Dec 9, 2003
dru106's Avatar
ThE CoRRupToR
I say u have someone professional install it for u
CarStuff
Dec 6, 2020 12:52 PM
Civic2002lx
Oct 7, 2015 09:17 AM
stereobumps
69
Jul 14, 2015 08:08 AM
izdman
May 19, 2015 03:43 PM
nicholaai
Apr 27, 2015 05:54 PM
