Gel coat and fiberglass
Old Dec 2, 2003
sivlercivic02cc's Avatar
sivlercivic02cc is an unknown quantity at this point
First does anyone know what the difference is and which I would use to make a custom sub enclosure and surround for my trunk. Also where I can purchase locally or on the net.
Thanks
Old Dec 2, 2003
Explosivo's Avatar
The dog told me to do it
Explosivo is an unknown quantity at this point
Well, I am only talking from what I know about our boat... Fiberglass is the actual fiber, embedded with the resin, while the gel coat is a thick resin (usually color) over the fiberglass. When it chips, you can see the strata of fiberglass & gel coat... Anyway, I have done glass repairs on our sailboat, but, never crafted anything out of it. I would say that you would either have to make a mold for the fiberglass, or create a plywood frame and build it up with glass... hope that helps.
Old Dec 3, 2003
Thanx for the info, getting ready to try and glass my trunk. I was wondering if it is the gelcoat that makes it smooth or is it sanding that does that.
Old Dec 3, 2003
Explosivo's Avatar
The gel coat will leave a smooth finish and will be more so after sanding. We use a 2-part epoxy paint on our boat that is difficult to apply, but leaves a very smooth, like glass finish. It's called awl-grip and available at most boat supply places... Anyway, I hope that helps. A glass guy at a boat shop should be able to give you all the info you need as they do that stuff all the time..
Old Dec 3, 2003
Thanx for the help man....
Old Dec 3, 2003
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
gel coat will only be as smooth as the fiberglass unless you pile it on really thick. All gel coat is is like a form of paint put over the product.
~nick~
Old Dec 3, 2003
white2K2EX's Avatar
I sure wish my car was newer
I would suggest having a shop or friend do your sub enclosure if you have to ask what the difference is. I'm not making fun of you. I'm just trying to save you from a LOT of frustration.
jdh022764
18
Nov 3, 2015 06:44 AM
General DIY
Sep 25, 2015 08:02 PM
beanhead
Sep 24, 2015 12:04 PM
naokigoffi
Aug 30, 2015 06:19 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
