Painting valve cover/fuse box cover
Old Nov 15, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
Question Painting valve cover/fuse box cover
I've seen this done before, but I need to ask; do I need to use high-temp paint? I know of some normal spray paint that matches my red exterior almost flawlessly, so I really want to use that if I can. Does the spark plug cover (the thing that says HONDA and VTEC on it) get too hot for normal paint? Thanks.
Old Nov 15, 2003
TeLLy's Avatar
Yes, it's an Acura EL
I painted mine with Duplicolor Metalcast. The cover doesn't really get very hot, in fact I opened my hood and popped it off to paint it right after driving my car for half an hour.
Old Nov 15, 2003
jwalker87's Avatar
Bodacious Member
coo; prolly using the paint that matches my exterior then
Old Nov 15, 2003
i painted mthe honda vtec on mine with SSM touch up paint, so my wire cover is anodized blue with silver lettering.. no problems yet.. although, the letters look hella swirly cuz the touch up paint applicator sucks to use...
Old Nov 15, 2003
jwalker87's Avatar
Bodacious Member
i forget who, but i got a secret tip on it....paint the valve cover (wire cover, spark plug cover, whatefver) the color you want the background to be. Then take a sharpie and write on the letters...looks great. I want to do mine tomorrow...just have to buy some paint.
Old Nov 15, 2003
Joey_Zazza's Avatar
Joey_Zazza is an unknown quantity at this point
ya
I painted my cover as well, i sanded it lightly with sand paper (wet), then used high temp primer, and high temp paint. You dont need to use high temp paint because it doesnt get that hot, but i did just in case. It came out tight and i have no problems with it.
Old Nov 16, 2003
xX03EXx's Avatar
Sweetest Dude on 7th Gen
I used high temp paint, not because it necessarily needs it, just for the piece of mind it gives me. All i have to say is take time to mask off the letters on the valve cover, it looks 100% better when they are a diff color IMO. Just get high gloss high temp paint and forget about it.
Old Nov 16, 2003
AzNBonD's Avatar
AzNBonD is an unknown quantity at this point
You don't need high temp paint. The spark plug cover really doesn't get that hot. Even after hours of driving, you can still handle it with bare hands without much discomfort.
Just make sure you clean it well before painting; well just don't have any grease/oil on the surface. Or else your paintjob might not end up that nicely. Some people like to use wash grade acetone on a cloth to clean the cover, but soap/scrubing/water does the trick as well.
usajags84
15
Aug 19, 2015 03:12 AM
JohnnyBxo
16
May 9, 2015 05:53 PM
bambuski
Dec 16, 2001 05:57 PM
slammed2k1civ
Nov 6, 2001 11:52 PM
