4DR owners! HELP@!!!
hey guys i need some help...i just recieved my Hybrid taillights for my 4dr...i figured out how to remove the trunk attached one...but how do u remove the other 2...do i have to remove the bumper to do this? is there a DIY guide out there??!
Originally posted by smoke4
there is a nut underneath holding the outer tails on. you don't HAVE to take the bumper off to get the lights off. It helps, but you don't have to.
did you take out all the screws from inside the trunk? you have to pull back the mateial to get access to it.
lease: Registered!!
Taking off the bumper would be the easiest way if you really can't remove the lights. I didn't remove the bumper when I changed my tails. Have you tried lossen the metal rack inside the bumper and pulled the light out?
Hey man--when I put my stock lights back on without taking off the bumper, I literally had to bang them in. They won't come out unless the bumper is off.
I don't think it is hard to take off the bumper. I was just lazy to take it off. That's all. You have to loosen the screw underneath the light for sure, but if you can't loosen the nuts inside, nevermind, take off your bumper then you can surely get the lights out very easily!
There are screws underneath both fenders, two clips on the bottom of the bumper, and two hidden bolts (under black covers) when you open the trunk. Then the bumper pulls off from the sides. You have to pull, since it's held on by internal clips.
brags
Oct 2, 2015 05:53 AM
Hutch1051
Sep 29, 2015 09:20 AM
