help!high beam not working
ok.. just got done painting my headlights(housing).. and when i put it all back together and i checked if everything works.. i noticed my drivers side healight is weaker than the passengers side... and when i switched to high beam the drivers side light turned off... did i mess up my bulb? is there a solution??
End Bringer
if the blub looks weak during low beam, and no light for high beam, the fuse maybe blown, it could also be the headlight relay, but most likely fuse
if it's fuse, make sure when you do any sort of work near electronics or on electronics on your car, disconnect the negative terminal of the battery
drl = day time running lights
Hey ferio..this isnt anything about your topic..but where'd you get the jdm sidemarkers..ive been wanting to get sum for a while.Oh..and since you black housed your headlights..make sure they dont fog up...test it, wash your car and see if the thing fogs up..cuz when i first black housed mine, they fogged up once i washed my car and i had to do the whole damm thing over again
intensity
May 12, 2015 10:43 PM
ORskier
May 3, 2015 12:54 PM
