Intercooler Piping
I need pics and/or information about running IC piping on either side of the intercooler....
Facing the car: the left side is easy
the right side is confusing to me, I relocated (well actually just took out) my
wiper fluid bottle....
Does anyone have pics of this or can tell me how they ran the piping?
Brandon
also question for catalyst
how much is the alcohol system shipped and how long does it take to install on a "custom" turbo kit?
Brandon
this has been an atl01 production..
no, it fits fine. If you want to see pictures. Go to importsouth.com, then go to event coverege. check out the Godfather custom spring jam show. On page 14, the second and third pic on top row, and the first pic on the second row. I would do a link, but have no idea how to.
Originally posted by zinkyroo
What is that guy running for fuel
dont have a picture, but had to remove the washer bottle, remove the ac compressor, also if ur going that route then the bend around from the front needs to be kinda wide, i used a Greddy type 31 gsr kit and had to modify the driver side to make around the bend
All you have to do is come out of the intercooler come right up where the washer bottle used to be ( there should be a hole there where the neck of the bottle came out.), and then in to the intake. Sorry i dont have any better pics.
The abs lines are in the way, the power steering is in the way, as well as an assortment of other things.....
however, i found a way to run from where the washer bottle was and then right under the headlight housing, which is also right below the power steering pulley..... 2" piping fits perfectly, and then I will have this piping run right in front of the fan shroud and into the turbo....this works out perfectly and looks so clean....the piping on the left side of the car will go to the throttle body....
Brandon
Brandon
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
michael0219
Sep 1, 2015 10:25 PM
PierrePierre
Aug 12, 2015 02:42 PM
Causemo
Jul 5, 2015 06:42 AM
