Intercooler Piping
Old Nov 5, 2003
chesireCAT's Avatar
chesireCAT is an unknown quantity at this point
Exclamation Intercooler Piping
I need pics and/or information about running IC piping on either side of the intercooler....
Facing the car: the left side is easy
the right side is confusing to me, I relocated (well actually just took out) my
wiper fluid bottle....
Does anyone have pics of this or can tell me how they ran the piping?
Brandon
also question for catalyst
how much is the alcohol system shipped and how long does it take to install on a "custom" turbo kit?
Old Nov 5, 2003
wannabeblown's Avatar
wannabeblown is an unknown quantity at this point
I'm doing mine this weekend, i'll take pics.
Old Nov 5, 2003
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
Thats what i did. took out my windshild wiper resivior, and ran the piping and ran it through the hole that is left there. It is a perfect fit.
Old Nov 5, 2003
chesireCAT's Avatar
after you get through that hole then where do you go from there? over the top?
Brandon
Old Nov 5, 2003
atl01's Avatar
over the top of the hoses and into the intake
Old Nov 6, 2003
chesireCAT's Avatar
there is room for that to fit? with the hood and all?
that sounds like it's gonna look like crap in the engine bay
Brandon
Old Nov 6, 2003
atl01's Avatar
no, it fits fine. If you want to see pictures. Go to importsouth.com, then go to event coverege. check out the Godfather custom spring jam show. On page 14, the second and third pic on top row, and the first pic on the second row. I would do a link, but have no idea how to.
Old Nov 6, 2003
civic01vtec's Avatar
just copy the image and save it to ur hardrive....then when u post a topic......scroll down to insert image and click browse.
Old Nov 6, 2003
MadWheel's Avatar
Premium Boosted Member
Did the work, here you guys go...
Old Nov 6, 2003
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
What is that guy running for fuel
Old Nov 6, 2003
atl01's Avatar
hey thank man!
Old Nov 6, 2003
prototype's Avatar
x-factor
thats hot...whos car is that?
Old Nov 6, 2003
atl01's Avatar
Me
Old Nov 6, 2003
C2i0v0i1C's Avatar
SuperMODrizd
same question here, do i see some sort of regulator and guage back there
Old Nov 7, 2003
chesireCAT's Avatar
Like I said the left side of the car is easy, can you show me a pic of how you did the right side??? I would greatly appreciate it....btw that looks really nice
Brandon
Old Nov 7, 2003
C2i0v0i1C's Avatar
SuperMODrizd
dont have a picture, but had to remove the washer bottle, remove the ac compressor, also if ur going that route then the bend around from the front needs to be kinda wide, i used a Greddy type 31 gsr kit and had to modify the driver side to make around the bend
Old Nov 7, 2003
chesireCAT's Avatar
Madwheel did you remove the ac compressor?????
Not many of us florida boys would like to do such a thing....
Brandon
Old Nov 7, 2003
MadWheel's Avatar
no i did not remove the ac compressor, but both of my pipes are on the passenger side
Old Nov 7, 2003
atl01's Avatar
All you have to do is come out of the intercooler come right up where the washer bottle used to be ( there should be a hole there where the neck of the bottle came out.), and then in to the intake. Sorry i dont have any better pics.
Old Nov 8, 2003
chesireCAT's Avatar
The abs lines are in the way, the power steering is in the way, as well as an assortment of other things.....
however, i found a way to run from where the washer bottle was and then right under the headlight housing, which is also right below the power steering pulley..... 2" piping fits perfectly, and then I will have this piping run right in front of the fan shroud and into the turbo....this works out perfectly and looks so clean....the piping on the left side of the car will go to the throttle body....
Brandon
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Cam Diaz
Sep 29, 2015 07:17 PM
michael0219
Sep 1, 2015 10:25 PM
PierrePierre
Aug 12, 2015 02:42 PM
Causemo
Jul 5, 2015 06:42 AM
